Sponsored by: Real Truck
Tire Pressure?
Old Jun 27, 2007 | 05:27 PM
DashingDaryl's Avatar
DashingDaryl
Tire Pressure?
The Door Jam on my 2000 F-250 Triton V8 2 wheel drive says I should have 50 pounds in the front tires and 80 pounds in the rear tires.
My tires say the max pressure is 44.
What does this mean, and what would you do?
I occasionally fill the bed with gravel, mulch and junk, but I never tow anything.
I don't have the brand of tire at hand, but they are stock size.
Old Jun 27, 2007 | 05:34 PM
bpounds's Avatar
bpounds
I guess it means you don't have the original tires. You apparently have load range D tires now, and it was shipped from Ford with load range E tires.
Bill
Old Jun 27, 2007 | 06:48 PM
jim henderson's Avatar
jim henderson
Yeah, you must have changed tires to a lower load rating so....
1) Do not exceed maximum inflation.
2) If you do haul a heavy load, increase the pressure upto maximum to at least give the tires their max capacity.
3) VERY IMPORTANT... Read the sidewall to find out what weight is the maximum you can handle with those tires. Now you need to do some guestimation. If for example the tires say the maximum load is 2,000#s(typical big car tire) at max inflation then theoretically your truck with load can weigh about 8,000#s. I don't know your model year and you don't have details, but in general a F250 Heavy/Super Duty with full tanks and passengers weighs well over 7,000#s. You can check at a public scale. Subtract the KNOWN weight of the truck and passengers and fuel from the max rating of the tires and that is what you can safely haul.
3A) The problem now is whatever load you put in the bed has to be below the total capacity of the tires. More accurately the weight per axle has to be below the capacity of the two tires on that axle. The weights per axle can be different depending on your truck and how you load it.
3B) If you exceed the tire rating, your risk of blow out goes up significantly.
4) I forget the exact terms but a full scoop of mulch weighs around 1,400#s and up depending on type and whether it has been raining. A scoop of gravel could well be way over capacity.
You need real truck tires if you plan to haul heavy loads for more than a few blocks.
I have popped trailer tires when overloaded about 50% in just a few miles, no fun.
Good Luck,
Jim Henderson
Old Jun 28, 2007 | 12:27 PM
DashingDaryl
Hey thanks! I bought a "new to me" set of OEM Ford rims and those were the tires on them.
I will trade them out for "E" rated tires.
Old Jun 28, 2007 | 12:34 PM
bpounds's Avatar
bpounds
Double check the rims to be sure they are rated for enough load. Don't know why the wouldn't be if they are OEM Super Duty rims, but still you might as well check. Should be stamped inside the rim.
Bill
