DP-tuner
Old Jun 26, 2007 | 06:26 PM
powerstroke1869's Avatar
powerstroke1869
DP-tuner
im planning on getting a dp-tuner i plan on just getting right now stock, 80econ and im debating between 140 smoke and 120 race which one would you guys who have ithe tuner recommend and also besides the boost anhilator is there anything else i need thanks in advance
Old Jun 26, 2007 | 06:38 PM
countrystrokin''s Avatar
countrystrokin'
Some of the guys will chime in and help out. Im going to watch this therad....I was also thinking the same for my psd
Old Jun 26, 2007 | 06:45 PM
Uzumati's Avatar
Uzumati
If I had it to do again i would not have gotten the 140..I just never use it.
It is not required but a BTS valve body tuned to the tuner and the tuner tuned to the valve body is a good upgrade.
Old Jun 26, 2007 | 06:47 PM
powerstroke1869
so prolly my best bet would be to go with the 80econ and the 120race
Old Jun 26, 2007 | 06:57 PM
Meatco1's Avatar
Meatco1
I had a DP tune, & a "John Wood" trans installed the same day. With the DP I had 20, 40, 60 tow, 80 econ., & 120 race tunes.
For the most part I usually run in 80 econ, and rarely use the 120 race (but it is fun!!) . The low tow settings are used when towing and climbing the Mts of Colorado.
They do manage to keep my egt's down to bearable while keeping my speed up.
Richard
Old Jun 26, 2007 | 10:06 PM
Izzy351's Avatar
Izzy351
I got 80 Econ & 120 Race (besides the freebies). Excellent tunes...
Old Jun 26, 2007 | 10:17 PM
mudracin74's Avatar
mudracin74
i have 40,80,120,140. i normally run the 80 econ. other than the 80 the next most used tune i have is the 140. it make some awsome smoke. its also the tune that wakes my rig up the most. just me but id go 140 over the 120
Old Jun 26, 2007 | 10:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
The 140 tune will really chug out some smoke. It has great throttle response, and it's what i was on when i made the picture in my signature. It wakes the truck up down low, but up on top my HPOP suffers. I make about 25-26psi WOT with the 120 and 140 programs, however if i run in the 80 econo, it seems to take longer to get there, however on top the power does not fall off as fast like it does on 120 and 140. I can make 30-31psi of boost with my .84 turbonetics in the 80hp tune.
Old Jun 26, 2007 | 10:40 PM
misterfisher's Avatar
misterfisher
You will need a buddy with lots of cash to bail you out of jail every time you floor it LOL! Best thing I ever bought for my rig. THe 80 econ is good, the 140 Race is a bit muchf or the stock HPOP and makes lots of smoke to boot. He has a lumpy idle tune as well.
Old Jun 26, 2007 | 11:20 PM
John311t's Avatar
John311t
A got a good question, my TS chip ont he highest setting makes this god awful grrrrrr noise, if im to the floor it does it when i let up a little it goes away and the power comes back.
Does anyone know what this is?
Does the DP chip also do this?
Old Jun 26, 2007 | 11:26 PM
Meatco1's Avatar
Meatco1
I have no unusual noises at all, using the the DP chip
Richard
Old Jun 26, 2007 | 11:28 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I have had the TS and now a DP. Never had that. The TS ran very well. The DP tunes are much stronger. I have a stock, 60tow, 80econo, and 120 race. At the drag strip I made many runs. Interestingly, I was able to duplicate for the most part my times in the 120race when I switched to the 80 setting. Take it for what it is worth. Probably maxing out the HPOP.
Old Jun 26, 2007 | 11:41 PM
John311t's Avatar
John311t
Hmm, i read something at ADM about it and they were talking about detotnation, and such but never got to the bottom of it? It sounds like my motor is rattling apart when it happens.
Old Jun 26, 2007 | 11:59 PM
Tenn01PSD350
Wow. Didn't know a diesel could detonate. Maybe I will learn something here but don't see how detonation could happen there. No spark plug after all. My TS never even came close to that.
Old Jun 27, 2007 | 12:08 AM
rebelchevy02's Avatar
rebelchevy02
I think I know what your talking about, I noticed it when I had only the 10k mod, which was a while ago now, I think it waslow to mid range rpms(1600-2k IIRC), sounds more like a drivetrain bind then anything else? Not that me confirming really helps, but I think that would mean its in the hpop since the only mod for me at the time was the 10k mod? If we had the same noise?
