Burnout fun in my '01
Took a little video this afternoon thought you all would appreciate too. Bone stock 4.2L with the muffler cut off(you can see my rigged up exhaust hanging down in the vid)
http://vids.myspace.com/index.cfm?fu...oid=2039769522
Heres my posi's with my truck...
http://i158.photobucket.com/albums/t82/BurnsMGT/DSC00385.jpg
and right when the marks start to go back towars the left is when i hit second gear... (with an automatic) and it still pulled another several feet....
that was the 93 octane tune and i only held the brake long enough for the RPM's to let the tires rev up past 4k... then she pulled the rest... the motor was in its sweet spot and the smoke was imense rolling from the tires...i was very impressed with my EDGE.. and my 4.6l...
with the right amount of brake and the right amount of gas(at the same time) you can leave as much rubber as you want. The clutch throws a wrench in it, but it can be done (see above LOL) I HAVE to hold the brakes for my little V6 to pull smoke like that. And that was after the tires were already warm. I've left some VERY long patches tho out on back roads....I'da probably kept going there if I wasn't to the end of my driveway LOL.
I did something like that the other day in my 97 F150 4.6 auto. Mine is bone stock. I did sit and let 'em roast before letting off the brake. I only have the one wheel wonder. Still impresive to see though. I did this with 200k on the clock. Probably wont do it much anymore as I don't want to break anything.
Well of course...but the problems with these trucks is that in stock trim and and auto they normally wont get the tires turning over on normal dry pavement... at least my truck wouldnt and my dads 01 screw with a 5.4l and a 4r100...
And that was all motor after they initially spin.... not as impressive when you hold the brake the entire black mark.... kinda like myne isnt as impressive as sombody who left marks like that with no brakes at all... lol
