Offroad & 4x4
Axel idetification 4x4 Van
Old Jun 25, 2007 | 07:50 PM
74X4VAN's Avatar
74X4VAN
Hi all u Truck Nuts.
I am trying to find out what this Van has for the front axle?
1974 E-300, window, 4x4, (302 HO 1987) C4, Dana 20.
Front axle tube shaft numbers are 1214 3 C9 603419 2.
Metal tag on pumpkin is 45-11 4.09 .
Old Jun 26, 2007 | 12:11 PM
fishmanndotcom's Avatar
fishmanndotcom
if its an E300 i am gonna take a shot in the dark here and say its a low pinion, closed knuckle Dana 60. but i cant be sure. hopefully someone here can help
-cutts-
Old Jun 27, 2007 | 04:38 PM
74X4VAN's Avatar
74X4VAN
Might be a Pathfinder
It's an open knuckle,low pinion, 10 bolt pumpkin, 2-3/4" axle shaft housing, 8 lug, drum brake, coil springs, drag links.
It may be a pathfinder van?
I can't find a Bill Of Material list with that number on it.
Old Jun 27, 2007 | 06:12 PM
75F350's Avatar
75F350
Just check the size of the bolts holding the inspection cover on it. If they require a 1/2 incch wrench, you have a D44, if it requires a 9/16" wrench, you have an open knuckle D60 with a low pinion and a 4.09 ratio.
Old Jun 27, 2007 | 07:28 PM
74X4VAN's Avatar
74X4VAN
1/2' bolts
Ok so if I want to convert to disc brakes what parts do I need?
Are all Dana 44 disc brakes the same?
Shocker
Oct 23, 2013 01:08 AM
kingdomflight
Jul 9, 2013 09:46 PM
LarryP2
20
Aug 14, 2012 09:28 AM
pfogle
13
Feb 16, 2003 01:24 PM
mech1
Sep 12, 2001 08:57 PM
