Help identify front 4x4 E350 axle
Old Oct 16, 2013 | 06:30 PM
Shocker's Avatar
Shocker
Hey guys, I am looking at this van. Converted 4x4 but I am not sure what front axle is has.
The van is a couple hundred miles from me so I had the seller take a pic.
Is this a D44 or D60?
Thanks!
Old Oct 17, 2013 | 08:42 AM
kb1jid's Avatar
kb1jid
Looks like a D44 and by the sway bar link a 1991 or older
Old Oct 17, 2013 | 10:20 AM
Shocker's Avatar
Shocker
That is what I was thinking. Do you guys think it is strong enough for the job?
The van is similar to yours KB, but with a 460 instead of the diesel. It is an ambulance.
Old Oct 17, 2013 | 03:45 PM
kb1jid's Avatar
kb1jid
mine is 8400# with out water or driver. 4180 on frt and 4220 on rear. Iam thinking about getting a D60 an making custom brkts to install using the 4 link that is in there now A D44 is only rated for about 3500# Mine was safe with the 351 gas engine in it but now that I have installed the 7.3 diesel Iam a lil over weight on the frt
Old Oct 17, 2013 | 03:57 PM
Shocker's Avatar
Shocker
Zoinks! I am not sure I want to go through the expense of installing a D60. Dang.
Old Oct 19, 2013 | 08:05 AM
LeoJr's Avatar
LeoJr
You may need to ask for another picture....there is some info about half page down that may be of help....
Axle Tech - Identifiacation, Dana 60, 14 Bolt, Eaton, Lincon Locker, Ect.
Old Oct 20, 2013 | 08:25 PM
Shocker's Avatar
Shocker
Thanks Leo, the website seems to be down. Have you been able to get to it?
I spoke with the guys at Pathfinder and they say: All Pathfinder Dodge and GM vans as well as 90% of Fords have Dana 44's, they hold up just fine. I don't think you would need to worry about that.
I am sure that I will not be taking the van through the Rubicon so maybe it would be fine.
I did read that there were a number of Pathfinder coil conversions done on the E350 that used the D60.
It's funny, side by side you can tell right away, but not as easy from a photo.
Thanks for all the help everyone!
Meanwhile, I am getting ready to look at a 93 E350 4x4. Also a former ambulance. This one has the 7.3 IDI and a D60 front. It is still fully kitted out as a ambulance and I am not quite as fond of the later body vs the older one.
But the diesel, 4 speed auto and D60 front (not sure what the rear is). makes a difference. It does have the BW1356 transfer case (the 82 has the NP205) so that is not quite as tough, but again, I am not going nutz with the rig.
Old Oct 20, 2013 | 10:50 PM
Shocker's Avatar
Shocker
Dang, big reply and it all disappeared. Dang it.
Thanks for the info!
The Pathfinder guys tell me it is a D44 and that most all vans were converted using the D44. They say it is fine. Hard to argue with the 3500 GAWR for the D44.
Ok, now my post is back....
Old Oct 21, 2013 | 12:17 AM
Shocker's Avatar
Shocker
Ok, the website is back up, but I still can't tell for sure.
Here is a pic of the passenger side. It all looks kinda Dana 60ish...
Kingpins from what I can tell as well.
Old Oct 21, 2013 | 11:06 AM
kb1jid's Avatar
kb1jid
The above pic has ball joints on that frt end
Old Oct 21, 2013 | 11:26 AM
Shocker's Avatar
Shocker
Hehe, well ain't I stupid.
Thanks for the clarification!
Old Oct 23, 2013 | 01:08 AM
Shocker's Avatar
Shocker
Should there be a track bar?
racine
Engine Swaps
18
Jan 25, 2012 03:17 PM
SAR Skipper
Apr 11, 2011 12:41 PM
bronkntrukholik
13
Apr 28, 2010 07:32 AM
steddy
Sep 28, 2005 12:30 PM
Schmids4.9l
Offroad & 4x4
Aug 4, 2005 10:32 PM
