Replacing Rotors Need tools
Old Jun 25, 2007 | 12:41 PM
Neal 97 250's Avatar
Neal 97 250
I am replacing the front rotors on my wife's 2000 Excursion and I need to know if I have the correct spindle nut tool and if there are any more specialty tools that I need. I have one for an older truck but it doesn't work on my '97. Does anyone have a schematic of the parts? Any info and suggestions will be helpful.
I would ask in the EX forum but they mainly discuss cosmetic and towing stuff and I need technical things.
Old Jun 25, 2007 | 12:46 PM
John311t's Avatar
John311t
You need a hammer if its stuck. They are just a rotor, no hub assembly inside of it. After you take off the caliper, and mounting bracket and the pads the rotor will just slide over the lugs. If its stuck is may take some hitting to get it off, maybe some rust breaker. These brakes are not like the old ones.
Old Jun 25, 2007 | 12:59 PM
Neal 97 250
Oh. Thanx for the good news. I was thinking it would be like my '97. Boy you just made my day. I get them in on Thursday and have to go to the beach on Friday and I wasn't thinking I was going to be able to pull this one off. Whew!!!
So I assume regular hand tools is all I need?
Old Jun 25, 2007 | 01:03 PM
John311t's Avatar
John311t
Yup, the caliper slide pins may be a bit of a pain in the ****, if they have been on there awhile they maybe stuck inside the bracket. Be prepared for that. I belive its an 18mm socket, and 12mm for the caliper and caliper mounting bracket, but idr.
Old Jun 25, 2007 | 01:08 PM
Neal 97 250
Kool. The thing vibrates violently at high speed braking. I hope this is it. It needs them anyway. The thing that puzzled me is that the pedal doesn't pulse at slow stops it just works smooth. I am going to rotate and balance the tires hopefully today then the brakes next.
AlSwope
Nov 8, 2016 10:38 AM
DLogan
Mar 19, 2011 01:34 PM
blackop
May 27, 2007 11:17 AM
MudBugn
Jul 16, 2005 09:22 PM
97GreenRanger
1983 - 2012 Ranger & B-Series
Apr 6, 2004 05:30 PM
