Help!
Old Jun 24, 2007 | 10:04 PM
matt71's Avatar
matt71
The shim is on the bolt side between the bolt head and the flywheel. And no it will not go in to gear when the truck is running. When you start the truck in gear with the pedal depressed, the truck moves when starting.
Old Jun 24, 2007 | 10:08 PM
strokin'_tatsch's Avatar
strokin'_tatsch
did you get the single mass flywheel? in case you don't know what that means... is the flywheel solid or does it have springs in it?
Old Jun 24, 2007 | 10:13 PM
matt71's Avatar
matt71
Yes i changed over to the single mass flywheel. It is the LUK solid flywheel option.
Old Jun 24, 2007 | 10:18 PM
strokin'_tatsch
did you torque down the bolts on the pressure plate and did you make sure the clutch was in the correct direction... it is stamped on the clutch disc which way it goes. i think the metal piece on the clutch is tapered on one end
Old Jun 25, 2007 | 07:56 AM
mr clutch's Avatar
mr clutch
replace your slave and master. alot of times when you switch to the solid flywheel, the new clutch is alot stronger than the old one and your hydraulics are usually just as old. your not getting full release because the fluid is passing by the seals internally. replace the slave and master and you will be good to go. look at my web site for proper bleeding instructions. if you pump the pedal it will be a long day trying to bleed them. let me know if you have any questions
Old Jun 25, 2007 | 01:20 PM
strokin'_tatsch
why would you have to change out the master also? i would think that if the fluid is passing by the seals internally then the master should be good and you could get away with just replacing the slave.
Old Jun 25, 2007 | 01:35 PM
matt71's Avatar
matt71
Changed the master and slave cylinders today and im pretty sure i got them bleed out good. I blead them until the slave cylinder got real hard to push. It shifts better but the pedal is still not very hard and the clutch grabs right off the floor.
Old Jun 25, 2007 | 06:00 PM
strokin'_tatsch
try to bleed it a little more and see if it gets better. glad you got it back right
Funke1
Jan 31, 2015 10:32 AM
crerar
Dec 13, 2011 09:12 PM
jlh192006
New Member Introductions
Feb 16, 2007 12:04 AM
CougarMark67XR7
Jun 18, 2005 05:18 PM
Varnish
Apr 27, 2002 01:31 PM
