Clutch replacement questions
Old Jan 31, 2015 | 09:56 AM
Funke1's Avatar
Funke1
I have a '75 e150 with a 300 6 and a 3 on the tree manual. My ring gear is all chewed up, so I'm going to replace it and the clutch as well.
Am I going to need to use any shims after I resurface the flywheel and why?
Also, What torque do the flywheel and clutch bolts need to be set at?
Old Jan 31, 2015 | 10:32 AM
The Frenchtown Flyer's Avatar
You will not need to use any shims on the flywheel or pressure plate. The '75 has a mechanical adjustable clutch actuator rod so the proper clutch pedal free play can be set, which I think is about 3/4 inch.
I suggest using grade 8 bolts to attach the pressure plate, with Locktite.
Dunno the torque spec offhand - it should be Googleable.
dieselsubmariner
Jan 11, 2015 10:39 PM
fifty-two_f1
Dec 3, 2011 06:25 AM
LS3
Dec 1, 2010 10:52 AM
99SevenPoint3
Oct 29, 2009 07:21 PM
kcasteel
May 20, 2009 04:22 PM
