question about white smoke
Old Jun 23, 2007 | 09:07 AM
ponch37300's Avatar
ponch37300
So i pulled my oil filler cap off today while the truck was running and there was some smoke coming out of it. Now i remember reading that this could be blow bye but i also remember reading that this might be normal. Can someone explain this and tell me what i should look for to make sure nothing is wrong with the engine. Thanks
Old Jun 23, 2007 | 09:13 AM
rbaker6336's Avatar
rbaker6336
these engines have a good bit of blow by so may be normal what you are seeing
Old Jun 23, 2007 | 09:59 AM
ernesteugene's Avatar
ernesteugene
You could install a CC pressure gauge like I did, and then monitor your CC pressure under various load conditions. The max seen by both myself (while towing) and by Guzzle who also made some towing measurements is about 1.6" H2O. This # is for trucks with a CCV mod, you'll see a slight vacuum under load with a stock CCV. Ford has a test and a spec for blow by that both I and Alan Miller have posted, but the test requires a special oil cap and a gauge. A quick experiment is to remove the oil filler cap and zip tie a X4 folded white tee shirt over the filler tube and go for a drive, then post the pic and I'll compare it to my similar test.
Old Jun 23, 2007 | 10:05 AM
rbaker6336's Avatar
rbaker6336
if it's not using a bunch of oil I would forget about it and do CCV mod
Old Jun 23, 2007 | 05:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
A constant stream of oil mist is normal. What you do not want is a puff puff puff stream.
884x4broncoII
18
Dec 21, 2008 02:24 PM
tndiesel
Aug 17, 2008 10:22 PM
BillyBob69
16
Apr 29, 2008 02:42 PM
AtoJ
Nov 15, 2006 10:05 AM
greghoffmann
Mar 22, 2001 01:13 PM
