Coil Spring help!!
Old Jun 23, 2007 | 07:47 AM
jake47's Avatar
jake47
Coil Spring help!!
How do you remove a front coil spring on a 1990 4x4? I have the bottom nut off, what next?
Old Jun 23, 2007 | 10:53 AM
RangerPilot's Avatar
RangerPilot
I assume you have everything out of the way.
You need one of two things. Either a coil spring compressor, or a jack.
If you use the coil spring compressor, let the suspension fully compress sitting on the ground, insert and tighten compressor, extend suspension with a jack or whatever, and the spring comes right out.
If you just use the jack, remove the front shock, then lift the truck up until the tire is off the ground and the coil spring should come right out.
kaneabel
Jul 27, 2016 06:19 PM
Sayer Lane
16
Dec 23, 2014 01:46 PM
mrwrench
34
Feb 16, 2009 03:37 PM
StrokiN&SmokiN
Aug 11, 2008 11:52 AM
Ben_E
Aug 13, 1999 10:27 PM
