Knocking sound from driver side suspension.
Old Jun 21, 2007 | 01:35 PM
nathan5603's Avatar
nathan5603
I have a 2001 Ranger with a 2.3L and a 5 spd tranny. I have recently noticed a light knocking sound coming from suspension on the driver's side. I really noticed this when I was in a traffic jam and driving in first gear around 10 mph. It makes noise when I barley hit bumps in the road. Do you guys have any suggestions? Sometimes I feel the noise in the steering wheel too. Thanks in advance for your help. ~Nathan
Old Jun 21, 2007 | 01:50 PM
pgw85706's Avatar
pgw85706
Check your sway bar connecting links. Here's a couple threads on the topic to consider. The link is essentially a 10" long or so 5/16" bolt positioned vertically that ties each end of your front sway bar to the frame. Let us know what you find.
https://www.ford-trucks.com/forums/6...highlight=link
https://www.ford-trucks.com/forums/5...onnecting+link
Old Jun 21, 2007 | 07:30 PM
nathan5603's Avatar
nathan5603
Thanks for you help. I checked the sway bar links and they both look good on each end. I started shaking each side of the suspension and only heard noise on one side. It was the right side. I think it might be the catalytic converter that's loose. Do you have any ideas? When should the shocks be replaced?
Old Jun 22, 2007 | 04:11 AM
pgw85706's Avatar
pgw85706
Nathan, If the noise is more like a rattle, check the heat shield on your muffler. A shock mounting bolt could be loose as well. The life of your shocks will of course depend on your mileage and driving style. If your shock inspection shows leaking oil, then for sure replace them. There is also the bounce test where you try and rock the truck (by maybe jumping while standing on the bumper) and see how quickly the truck dampens back to still. If it continues to bounce more than 3 times after you stopped, then the dampening fluid is likely spent and you should consider replacement. I'm sure others can offer further guidance. I just replaced the shocks on my '99 Ranger at 65k miles with good results.
Keep us posted on what you find. Pat
Old Jun 23, 2007 | 02:33 AM
brianjwilson's Avatar
brianjwilson
You would have to physically tighten the sway bar endlink bolts to determine anything. They can make noise like that even if they look tight (they need to be REALLY tight). Also check and tighten all of the shock mounts and such. How many miles? A common problem is also the lower balljoints.
Try having a friend bounce the truck while you are underneath (with the brake on of course). You might need to use a long handled screwdriver to pinpoint the niose. Handle side pressed to your ear while the other end is placed on various parts.
Old Jun 23, 2007 | 11:12 AM
nathan5603's Avatar
nathan5603
Thanks for the help. I'll look at that tomorrow. The truck has 57,000 miles.
Nathan00
2004 - 2008 F150
Oct 1, 2014 05:48 AM
BuiltFerdTough
Feb 16, 2012 05:22 PM
NV250
Exhaust Systems
Oct 26, 2009 03:53 PM
Nathan
Dec 27, 2002 11:18 AM
Nathan
Jun 5, 2000 07:59 AM
