A/c
Old Jun 22, 2007 | 11:37 PM
67rangerxlt's Avatar
67rangerxlt
A/c
I am having a brain fart tonight.IT got hot here today and finally kicked on my A/C but it is cycling on and off at intervals of about 10 seconds. And i can't find any of my manuals tonight. any ideas would help. thanks in advance.
Old Jun 22, 2007 | 11:40 PM
Brimmstone's Avatar
Brimmstone
Sounds like you have a pressure problem. What year truck is it to start with.
Old Jun 22, 2007 | 11:43 PM
67rangerxlt
it is an 86 f-250 4x4 6.9 4spd. low side pressure is 55 with compressor disengaged and 23 when compressor is engaged.
Old Jun 22, 2007 | 11:45 PM
Brimmstone's Avatar
Brimmstone
There's your problem. You need it to be at least 40 with it engaged. It's dropping to low and throwing the low side pressure switch. It sounds like you have a small leak in the system. Is it R-12 or R-134a
Old Jun 22, 2007 | 11:54 PM
67rangerxlt
it is R134 i think i might have just found the leak. the high side port is bubbling a little. that is probably my problem.
Old Jun 23, 2007 | 12:02 AM
Brimmstone's Avatar
Brimmstone
Yep. You'll need to have it replaced. Take it to a shop and have it recharged. I know it costs a bundle but you'll be happier with the results. You can get a replacement core for the high side pretty cheap. I usually get the kits from Advance Auto. I think the kit is like 20 dollars.
Old Jun 23, 2007 | 12:10 AM
67rangerxlt
it was the conversion fitting for 134 making it leak. pulled it off and just added a can of 134 ran for five minutes no leaks and 52 degree air at vents. i will check it again in morning to see how much leaked out. thanks for the help. i love this web site.
Gary Lewis
Oct 16, 2012 04:45 AM
JIM ROLAND
60
Jun 12, 2010 09:23 AM
greagin
16
Sep 7, 2008 12:17 PM
trailor
1997 - 2003 F150
Feb 22, 2007 12:21 PM
