Sponsored by: Auxito
More A/C problems.....
Old Feb 21, 2007 | 06:55 PM
trailor's Avatar
trailor
alright, i put in a brand new heater core two weeks ago, due to my last one leaking. did not have a/c decharged (or whatever it is). it seemed to work fine at first. now the a/c is not cold and the heater is not hot. all that blows out is air that is somewhat warm, but definitley not hot or cold. going to try to recharge it tonight or tomorrow, but not sure thats the problem, any ideas???
Old Feb 21, 2007 | 07:33 PM
torkum's Avatar
torkum
Sounds like your blend door is not moving all the way in hot or cold setting.
Old Feb 22, 2007 | 01:35 AM
trailor's Avatar
trailor
the weird part is that it seems the warmer air blows when i have it on cool, and the cooler air blows when i have it on warm... maybe its just a coincidence or bad timing (considering the weather changes more than i change my underwear in new orleans, and i change my underwear at least once a day mind you). if it is the blend door, how am i supposed to fix it? i know where it is and how to get to it, but what do i change/fix/adjust once i get there?? thanks in advance
Old Feb 22, 2007 | 06:29 AM
projectSHO89's Avatar
projectSHO89
Check the control **** first... They tend to cack and then spin in the control shaft.
Steve
Old Feb 22, 2007 | 12:21 PM
trailor's Avatar
trailor
i had the **** replaced about 8 months ago cuz the old one cracked, checked out the new one and it appears to be fine.. im recharging it today and if that doesn't work, ima go check the blend door and pray thats all it is
Tulsamulerider
Jan 10, 2017 10:28 PM
superman7928
Jan 30, 2015 03:08 PM
Jeff West
Feb 18, 2014 09:55 PM
joners
May 24, 2010 06:07 PM
Davez99Expy
Oct 21, 2004 10:22 PM
