Aerostar Ford Aerostar
Need help with codes
Old Jun 21, 2007 | 03:10 PM
ghenryl's Avatar
ghenryl
My 93 3.0L Aerostar is missing at 45-65 mph.
I have changed the plugs, rotor and cap.
Before I replace the wires (hoping I dont have to) I pulled the codes.
157- MAF sensor went below 0.4 volts during last 80 warmup cycles
(I have read in other posts that this indicates the MAF may need cleaning or replacment.)
But what does this mean?
212- Loss of IDM input to EEC or SPOUT cicuit grounded
thanks
Old Jun 21, 2007 | 03:49 PM
copper_90680's Avatar
copper_90680
The MAF code is pretty self explanatory. You need to clean the MAF and if that code still persists, you need to change it.
The code about SPOUT being grounded means either one of you spark plugs has been shorted out, or one of your wires has worn through and is shorted to the block.
Just because your spark plugs are replaced recently really doesn't mean much if your O2 sensor is busted. I replaced my plugs and one of them was fouled up and gave me that code again within 2 weeks before I realized that my O2 sensor was gone and that made my engine run rich, resulting in fouled plugs. Beware that, on OBD-I systems, you usually do not get a code if your O2 sensor goes bad, at least I didn't.
Old Jun 21, 2007 | 05:24 PM
96_4wdr's Avatar
96_4wdr
other causes of C212 are:
from Ford Service CD
DTC 18/212 indicates a loss of IDM input to the PCM.
Possible Causes:
-- Open harness circuit.
-- Shorted harness circuit.
-- Damaged Ignition Control Module (ICM).
-- Damaged Powertrain Control Module (PCM).
To prevent the replacement of good components, be aware that the following non-EEC areas may be at fault:
l Ignition Control Module (ICM)
l Ignition coil
l Spark plugs and high tension cables
l Distributor
l Arcing of secondary ignition components
the dirty MAF is caused by plugged failed air filter or leak in air box seal or the tube to the MAF.
can also be caused by
oiled cloth type ?performance? air filters
failed PCV valve or excessive crankcase blowby....check and change the PCV if sticking or older than 30k miles
remove the MAF element and soak in TB cleaner for 30 minutes...examine with magnifying glass for spotless clean wire and glass element
Old Jun 21, 2007 | 07:45 PM
ghenryl's Avatar
ghenryl
About ready to throw in the towel and sell as is where is.
By the way I said it was a 93 it is actually a 94.
I had the van running pretty well except for the miss at 45-65.
Well I just cleaned the MAF with MAF spray cleaner. I know you said to soak it for 30 min. and in another post someone said to soak in a shot glass but the configuration of my sensor is such that I can take off a small plate in front and see through the sensor but its not that small to soak just the filament. Id have to immerse the whole casing in a pail.
I also sprayed the throttle body plate and changed the pcv. The upper pcv elbow hose was basically falling apart so I wrapped in electrical tape so I could get it together enough to see how it would run until I can find a new hose.
Anyway now it runs 10 times worse. Seems I should have left well enough alone and replaced the wires. Maybe I would have gotten lucky and thats all it needed.
Not a good day here...
Old Jun 21, 2007 | 08:25 PM
96_4wdr's Avatar
96_4wdr
MAF cleaning is not Ford approved but then they like to sell parts.
removing the MAF element involves removing the 2 security torx screws on top holding it into the cast aluminum housing... can loosen the screws with a small set of pliers or small visegrips if no security torx bits
cleaning is not guarenteed to solve all MAF problems...the wire/glass elements are fragile and do get caked with grit grime that cooks on and cannot be remove or the wire element burns thru or breaks
i've replaced several on several rigs...Ford MAFs seem to be more fragile....elements break on rough logging roads
Old Jun 21, 2007 | 11:31 PM
xlt4wd90's Avatar
xlt4wd90
ghenryl,
Are you sure you you properly sealed the PCV hose? Leaking unmetered air into the engine will definitely make it run rough.
The MAF sensor elements on a Bosch system I saw once looked like strands of a spider's web. The Ford sensor elements seem positively studly in comparison.
Old Jun 21, 2007 | 11:38 PM
Bear River's Avatar
Bear River
Former ******
If the problem got worse, you confirmed that the MAf sensor was in fact the cause. The code is very self explanatory. I just had my MAF replaced last week. If I were you, I would definitely repair the problem, especially when the computer tells you exactly what is wrong. Despite the fragile nature of Ford's part, I recommend the genuine deal if it can be obtained a competitive price.
Old Jun 23, 2007 | 06:54 AM
ghenryl's Avatar
ghenryl
I have another issue that I failed to mention. The flex tube on my exhaust system is split. It has been for some time. How much would that effect the idle? Would it be as significant as the history below might indicate?
The van ran rough/missed all the time before I changed the plugs, rotor and cap...got better afterward and missed at 45-65 mph...then went back to missing all the time after cleaning MAF and TB plate.
BTW I have been having a hard time accessing the forum. Has there been an issue with website?
thanks
Old Jun 23, 2007 | 08:22 AM
Bear River's Avatar
Bear River
Former ******
Since touching the MAF actually made the mis worse, I would say that the MAF is involved for sure. Check the wiring and plug to make sure they are in good order, and if they are, replace the MAF sensor.
Old Nov 17, 2007 | 09:53 PM
ghenryl's Avatar
ghenryl
Sorry I havent gotten back to everyone but I did get these issues resolved. I put in new wires and a MAF sensor. Now it runs great. I also found one of my wires was broken inside the boot on the spark plug side. Total cost $114.17 parts + $18.38 shipping = $132.55
Thanks for your input.
Old Nov 17, 2007 | 11:19 PM
96_4wdr's Avatar
96_4wdr
ghenryl
thanks for the feed back
all helps our data bank for new users just finding us and reminds the old timers who have fought the Aerostar wars before and will again
anin't no fun trying to to troubleshoot in that tight dark dungeon hole
the codes never lie, just they don't yell out clearly exactly what the problem is every time
Old Nov 17, 2007 | 11:41 PM
copper_90680
Hi Ghenryl
Thanks for getting back with your solution to the problem. We need more like that just so someone with a similar problem knows what to look for.
Good luck with the van.
Old Nov 18, 2007 | 03:59 PM
Aeroman59's Avatar
Aeroman59
Probably Broken Plug wire = Misfire at 45-65MPH
Still...... a new MAF sensor would likely improve performance of the engine anyhow! good idea to change your air filter every year & make sure no leaks into the airbox after the filter. Did your yellow CEL blink at you?
Nice to get the feedback,THanx
ATB Aeroman
Old Nov 19, 2007 | 12:22 AM
Pablo-UA's Avatar
Pablo-UA
Henry! Clear all codes and drive somewere around your suburb and read codes againe. I see often very old codes, that were not cleared after reparing. Unfortunatly OBD-II does not save time and date of storing codes, freeze frame only. Volvo truck saves time of every event. So to clean and run againe will show you what the code is really actual. When ECU stores code it usually turns CE light on.
Old Nov 20, 2007 | 01:06 PM
ghenryl's Avatar
ghenryl
I never had a CEL show up. I do not have OBDII and had to do KOEO to read codes. Actually I had a KOEO code of 11 (system pass). The MAF (157) and 212 code were in continuous memory. Could they have been old codes? I have had the battery disconnected before so I would assume the codes would have been cleared from long ago.
The van was running rough. Initially I was just going to change the plugs, rotor and cap. After doing that the van ran worse and I noticed my wires arcing. Thats when I read the codes. I probably broke the wire when I changed the plugs and put everything back together the first time.
Anyway, when I went to change the wires I found the #2 plug wire broken at the spark plug connector. I changed the MAF based on the continous memory code and since it only cost $87.00 and it and the wires were original (128000 miles) I felt better knowing they were replaced.
Thanks
dlmoye
1983 - 2012 Ranger & B-Series
Jun 9, 2012 04:36 PM
kdwilkes
17
Feb 3, 2007 03:12 PM
shultzy501
1997 - 2003 F150
Jan 10, 2005 06:12 PM
MILDOT
Mar 13, 2004 09:06 AM
chanroy
Aerostar
Jan 4, 2004 08:08 PM
