Need help with codes
I have changed the plugs, rotor and cap.
Before I replace the wires (hoping I dont have to) I pulled the codes.
157- MAF sensor went below 0.4 volts during last 80 warmup cycles
(I have read in other posts that this indicates the MAF may need cleaning or replacment.)
But what does this mean?
212- Loss of IDM input to EEC or SPOUT cicuit grounded
thanks
The code about SPOUT being grounded means either one of you spark plugs has been shorted out, or one of your wires has worn through and is shorted to the block.
Just because your spark plugs are replaced recently really doesn't mean much if your O2 sensor is busted. I replaced my plugs and one of them was fouled up and gave me that code again within 2 weeks before I realized that my O2 sensor was gone and that made my engine run rich, resulting in fouled plugs. Beware that, on OBD-I systems, you usually do not get a code if your O2 sensor goes bad, at least I didn't.
from Ford Service CD
DTC 18/212 indicates a loss of IDM input to the PCM.
Possible Causes:
-- Open harness circuit.
-- Shorted harness circuit.
-- Damaged Ignition Control Module (ICM).
-- Damaged Powertrain Control Module (PCM).
To prevent the replacement of good components, be aware that the following non-EEC areas may be at fault:
l Ignition Control Module (ICM)
l Ignition coil
l Spark plugs and high tension cables
l Distributor
l Arcing of secondary ignition components
the dirty MAF is caused by plugged failed air filter or leak in air box seal or the tube to the MAF.
can also be caused by
oiled cloth type ?performance? air filters
failed PCV valve or excessive crankcase blowby....check and change the PCV if sticking or older than 30k miles
remove the MAF element and soak in TB cleaner for 30 minutes...examine with magnifying glass for spotless clean wire and glass element
By the way I said it was a 93 it is actually a 94.
I had the van running pretty well except for the miss at 45-65.
Well I just cleaned the MAF with MAF spray cleaner. I know you said to soak it for 30 min. and in another post someone said to soak in a shot glass but the configuration of my sensor is such that I can take off a small plate in front and see through the sensor but its not that small to soak just the filament. Id have to immerse the whole casing in a pail.
I also sprayed the throttle body plate and changed the pcv. The upper pcv elbow hose was basically falling apart so I wrapped in electrical tape so I could get it together enough to see how it would run until I can find a new hose.
Anyway now it runs 10 times worse. Seems I should have left well enough alone and replaced the wires. Maybe I would have gotten lucky and thats all it needed.
Not a good day here...
removing the MAF element involves removing the 2 security torx screws on top holding it into the cast aluminum housing... can loosen the screws with a small set of pliers or small visegrips if no security torx bits
cleaning is not guarenteed to solve all MAF problems...the wire/glass elements are fragile and do get caked with grit grime that cooks on and cannot be remove or the wire element burns thru or breaks
i've replaced several on several rigs...Ford MAFs seem to be more fragile....elements break on rough logging roads
Are you sure you you properly sealed the PCV hose? Leaking unmetered air into the engine will definitely make it run rough.
The MAF sensor elements on a Bosch system I saw once looked like strands of a spider's web. The Ford sensor elements seem positively studly in comparison.
The van ran rough/missed all the time before I changed the plugs, rotor and cap...got better afterward and missed at 45-65 mph...then went back to missing all the time after cleaning MAF and TB plate.
BTW I have been having a hard time accessing the forum. Has there been an issue with website?
thanks
Thanks for your input.
thanks for the feed back
all helps our data bank for new users just finding us and reminds the old timers who have fought the Aerostar wars before and will again
anin't no fun trying to to troubleshoot in that tight dark dungeon hole
the codes never lie, just they don't yell out clearly exactly what the problem is every time
Still...... a new MAF sensor would likely improve performance of the engine anyhow! good idea to change your air filter every year & make sure no leaks into the airbox after the filter. Did your yellow CEL blink at you?
Nice to get the feedback,THanx
ATB Aeroman
The van was running rough. Initially I was just going to change the plugs, rotor and cap. After doing that the van ran worse and I noticed my wires arcing. Thats when I read the codes. I probably broke the wire when I changed the plugs and put everything back together the first time.
Anyway, when I went to change the wires I found the #2 plug wire broken at the spark plug connector. I changed the MAF based on the continous memory code and since it only cost $87.00 and it and the wires were original (128000 miles) I felt better knowing they were replaced.
Thanks
