how to connect truspeed
Old Jun 21, 2007 | 02:27 PM
zstyle01's Avatar
zstyle01
just ran through the instruction manual online (so i can see what i'll be doing when i get it) and wondering where is the abs module (speed sensor)? if i understand the directions correctly power travels from comp through yellow wire in truspeed out the green wire to the abs module?
Old Jun 21, 2007 | 02:58 PM
John311t's Avatar
John311t
The abs module, your gonna love this spot, is under your battery and then under this rubber piece, BUT the harness for it is basically under the module. I went ahead and loosen up the abs mod from the body, and pulled up enough to get to the connector. Correct way would be to probably pull the fender out.
Old Jun 21, 2007 | 03:03 PM
zstyle01's Avatar
zstyle01
are you talking about passenger side batery?
Old Jun 21, 2007 | 03:05 PM
John311t's Avatar
John311t
Drivers side. You have to find the two wires, splice into them and connect the box as it says. yes you are correct the input from the speed sensor goes into the box, then the box messes with the input and gives a higher output thus changing the speedo.
villestrip
Feb 16, 2011 05:48 PM
Bowie
20
Aug 12, 2009 07:22 PM
sdunham
Oct 7, 2003 12:23 PM
02superstroker
Aug 17, 2003 10:18 PM
DoctorSmaX
Jan 17, 2003 01:37 PM
