Truspeed question
Old Jan 8, 2011 | 07:05 PM
villestrip's Avatar
villestrip
Truspeed question
I just got a used Truspeed. I have an 06 that I want to install it on. Where is the ABS module located? Thanks
Old Jan 9, 2011 | 03:41 AM
npccpartsman's Avatar
npccpartsman
You should be able to plug in to the OBDII port and program it
Old Jan 9, 2011 | 09:23 AM
villestrip's Avatar
villestrip
Not this one. This one has to be spliced in. I think the tirepaq is the only one that does that.
Old Jan 9, 2011 | 11:28 AM
Zmann's Avatar
Zmann
I would sell that and just reprogram your pcm ,, the truespeed looks like a pain??
pcm recalibrate = dealer can do it the Automotive enginuity can do it ,, if u have an sct device they can do it
Old Jan 9, 2011 | 12:01 PM
EODguyJake's Avatar
EODguyJake
Fulltime INFIDEL!
From what I understand, the dealer can only program to account for up to a 33in tire. As for your OBDII programmers, let me lay this one on ya. A couple of weeks ago I ordered the Hypertech speedo calibrator. Tirepaq isn't made as a stand alone speedo calibrator anymore. The Hypertech won't program if you are using another tuner. Hypertech told me that if I tried to set the truck to stock, use their programmer, and reloaded my tunes, it would either override the Hypertech, or lock up my truck's ECU. They suggested I ordered their top of the line tuner that has tuning and calibrating functions. I called SCT and asked them. They said in theory that shouldn't happen because their product doesn't touch the module that calibrates the speedo. However, using that logic I shouldn't have to go to stock to use the Hypertech. I called Innovative, and they basically said the same thing. In the end, it wasn't worth the risk of locking up my truck's ECU. The Truespeed does look like a pain, but it may be the only option. I returned the Hypertech.
Old Jan 9, 2011 | 12:10 PM
npccpartsman
An SCT will NOT recalibrate the speedometer. It's tire rev function is part of the trans. reprogram.
Old Jan 9, 2011 | 12:20 PM
Zmann's Avatar
Zmann
From SCT
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
<LI class=Options>
From A/E
Tire Size Programming up to 40" ('99-'03 7.3L, and '04-'07 6.0L)
this is the best find someone with an A/E to do it for free
Old Jan 9, 2011 | 12:24 PM
npccpartsman
Maybe on the newest SCT's it's a function, but none that I've ever seen. Definitely not on the Xcal2 or 3 and not the older livewire's.
After searching the SCT site all I can find is 6.4 speedo correction. Can you provide a link??
Old Jan 9, 2011 | 12:26 PM
Zmann's Avatar
Zmann
maybe not ??
I should say the SCT x3 or sf3 is what I have experiance with
Old Jan 9, 2011 | 01:08 PM
dchamberlain's Avatar
dchamberlain
The module you're programming when you set tire size is the ABS module. So I don't see how it could effect the PCM programming. At least that's how it works with AE. You go to the ABS module and set the tire size. Up to 40" if I recall.
I'm somewhat curious about the effect devices like the Truspeed will have on the ABS functionality. The ABS monitors the speed of both front wheels individually, and the rear wheels together by measuring the speed of differential ring gear.
The Truspeed, and other devices like it, modify the rear ABS sensor signal to make it appear that the wheels are turning a different speed than they actually are. So the ABS module will see a different speed from the front speed sensors and the rear one. What does the ABS module do with this conflicting information and how does it effect ABS operation? I've never heard anyone speak to this before.
Old Jan 9, 2011 | 01:15 PM
Zmann's Avatar
Zmann
good question
mine must have been done by ford? it is right on gps with 35's
Old Jan 9, 2011 | 04:29 PM
Tim C's Avatar
Tim C
I have the truspeed on my 03 f250. I got it long before i got the AE so its still on there. The truspeed basically wires in AFTER the abs module on the superdutys. Therefore the abs still reads wrong (as in it "sees" a different speed than the vehicle is acutally going), but will still operate correctly as far as wheel lock up goes during panic stopping, since ive gotten the abs to kick in a few times. The abs sends a "conditioned" speed signal out to all the other modules, airbag, pcm, dash, wipermotor (for speed calibrated intermittent wipe, believe it or not) and the radio for speed sensitive volume if you have the higher end radios. The truspeed hooks in to that wire from the abs to every other module. On my 03 its under the left battery in the wheel well, but i think they moved it after 05 and im not sure if the wire colors would match up.
One other thing about the truspeed I dont care for but doesnt cause any issues as far as I know is that at low speeds like idling in a parking lot or backing out of the drive way the speedo needle bounces from its actual reading up to 35-40mph or so and back until I hit 10mph then it smoothes out
Old Jan 9, 2011 | 04:35 PM
cheezit's Avatar
cheezit
sf3 will do it.
so far as the ford limiting to 33" tires thats not true either. 275/65/20 is a factory tire thats 34"
Old Jan 9, 2011 | 04:39 PM
villestrip's Avatar
villestrip
Only problem is I don't have AE. So if I had someone change it would it ever need to be changed back other than changing tire size?
Old Jan 9, 2011 | 08:01 PM
Zmann's Avatar
Zmann
no .. anyone with the A/E could do it for u it is not locked to the truck
