Oasis Report Please!
1FMNU42S3YEB40344
06/21/2007
10:02:59
FCXWS446
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 EXCURSION BODY STYLE
LIMITED 4 DR 4X2 ENGINE
6.8L EFI SOHC
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/17/2000 BUILD DATE
11/17/1999 SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
06N05
EXTENDED WARRANTY - HEADLAMP SWITCH ****
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/02/2007
DEALER: Whitson-Morgan Motor Company,
WARRANTY CLAIM NUMBER: 030521 ODOMETER: 123757M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
1L1Z 9F924AA SWITCH SPD CNTRL 001 05S28E
REPLACED SWITCH AND JUMPER
here you are.
1FMSU45P33ED13492
Thanks
~Rick
1FMSU45P33ED13492
06/21/2007
16:55:57
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
WARRANTY START DATE
10/25/2003 BUILD DATE
04/23/2003 SALE MILEAGE
00060
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
12/16/2006
DEALER: Midway Ford Company
WARRANTY CLAIM NUMBER: 162914 ODOMETER: 059051M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 12B637BA WIRING ENG CNTRL SNS 001 14200A 42 DOES NOT OPERATE PROPERLY
59051 UPON VISUAL INSPECTION I FOUND THE EGR THROTTLE PLATE CONNECTOR DISCO NNECTED AND RUBBIND ON THE BELT. BELT HAD RUBBED THRU THE HARDSHELL CONNECT OR AND DESTROYED IT. COULD NOT FIND PIGTAIL CONNECTOR SO I HAD TO ORDER A H ARNESS. INSTALLED NEW CONNECTOR AND ROAD TESTED TO VERIFY CONCERN. COULD NO T VERIFY CONCERN AFTER CONNECTOR WAS REPAIRED.
12/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 12A690BA WIRING ASY EC SENSOR 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6584BA GASKET VALVE ROCKER 001 6584AR
ZC 20 002 MT6007
59051 ISPECTED FOR ENGINE OIL LEAKS AND FOUND MULTIPLE LEAKS. FOUND PASS SI DE GLOW PLUG HARNESS LEAKING. FOUND PASS SIDE VALVE COVER LEAKING. INSPECTE D AND FOUND REAR BOLT ON VALVE COVER CLOSES TO REAR AC AND HEATER LINES CRO SS THREADED AND NOT TIGHT. REPLACED PASS SID E VALVE COVER GASKET. REPLACED PASS SIDE GLOW PLUG HARNESS DUE TO BEING OIL SOAKED FROM LEAKY VALVE COVER
1/2/01-1183 4x4 motor and radio
2/21/01-2019--no trouble found
4/3/01-2717- rear spring spacers
VIN: 1FA6P8CF0H5320069
1FMSU45P33ED13492
06/21/2007
16:55:57
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
WARRANTY START DATE
00060
EXTENDED COVERAGES
12/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
12/16/2006
LABOR OP
CONDITION CODE
CONDITION DESC
ZC 20 002 MT6007
