Bad engine problems
Old Jun 20, 2007 | 11:24 PM
1woody's Avatar
1woody
Bad engine problems
I was driving my 95' f-250 4x4 and all of a sudden the power cut out and it ran horribly. It dropped down to a super, super rough idle. and floored could only pull 30 mph. It idles horribly, and would barely run. the problem was intermittent, then was constant, but now it won't start at all.(the battery is charged) When cranked over it used to start perfect for a second and then idle terribly and the SERVICE ENGINE LIGHT is on. I also replaced the cps and don't know what to do. i need to get this truck up and running. any help is appreciated, thanks.
Old Jun 20, 2007 | 11:49 PM
ltfox's Avatar
ltfox
Pull codes if you can, that will help. Start checking the valve cover harnesses for burnt connectors and wiring. You can remove the oil fill cap and smell under the covers for burnt wires. Check fuel filter....and fuel pressure.
Old Jun 21, 2007 | 10:06 AM
1woody's Avatar
1woody
Don't have a code reader yet. Can any one else throw out some different theories on why, just so i can know what different things it could possibly be.
Old Jun 21, 2007 | 11:29 AM
Action4478's Avatar
Action4478
Eliminate the valve cover wiring ,by visually inspecting it, It is a cheap test , then move on to the ICP, EOT, & IPR data. you will need a scanner if it isnt the valve cover wiring..Un plug the ICP & see if it smoothes out.....Picture here....
http://http://good-times.webshots.co...00331771CLARTD
Old Jun 23, 2007 | 10:42 AM
1woody's Avatar
1woody
valve cover wiring seems to be fine. unplugged the icp and that didn't help. To get the fuel filter cover off, do i use a big torx, or tap it loose with a small hammer. i know, dumb question. and it's not reverse threaded by any chance.
Old Jun 23, 2007 | 10:47 AM
79_250RangerLariat's Avatar
79_250RangerLariat
righty tighty lefty loosy with the filter cap. Sounds like you you have one of the torx caps it's an aftermarket filter (hate those things.... )
Old Jun 23, 2007 | 11:40 AM
SrqScion's Avatar
SrqScion
I'm still learngin powerstrokes, but oil presure problem maybe?? Have you checked the oil level in the HPOP tank? Little hex head plug on the top right side when you are looking at the motor. Should have oil up in there. Just a free easy check for ya. Also make sure the oil level in the crankcase is full.
Old Jun 23, 2007 | 02:02 PM
bkcowboss's Avatar
bkcowboss
How did you check the valve cover wiring? It is important to check the visual stuff up to the valve cover, remove the plugs and check for burnt pins, but the only way to ensure that the wiring is good underneath is by removing the valve covers themselves. The gaskets are reusable. Most of the problems are underneath the valve cover, and that is the way that I would lean at this point. If you need details on removing the valve cover let us know. There are some continuity tests you can do on the pins, for the injectors, but we willsave that for now.
Old Jun 23, 2007 | 10:48 PM
c00nhunterjoe's Avatar
c00nhunterjoe
definatly sounds like a classic uvc harness melting, pull the right side first and inspect that is normally the one to go
Old Jun 26, 2007 | 11:09 AM
1woody's Avatar
1woody
I will check all these things out. Thanks for all the help.
Old Jun 26, 2007 | 12:54 PM
tjbeggs's Avatar
tjbeggs
yep I vote valve cover harness also!
Old Jun 27, 2007 | 07:02 AM
Todd525's Avatar
Todd525
i am with tj on this as well. My truck did the same thing, was harness.
