Offroad & 4x4
welded rear diff
Old Jun 22, 2007 | 05:49 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Ahahahaha!!!
When your saying off ramp....are you referring to an off-ramp off of the interstate???
Old Jun 23, 2007 | 12:14 PM
powerstroker88's Avatar
powerstroker88
naw im referring to the offramp of the onramp on an interstatejus go weld the rear end since everyone else is to cheap to buy a regular locker
Old Jun 23, 2007 | 11:38 PM
fishmanndotcom's Avatar
fishmanndotcom
WE ALREADY DID!!!!! been there done that got the cookie and t-shirt! DAMN!
why spend $600 (or more depending on application) that does the EXACT same thing as welding? WHY?
to each their own... fine by me, BUT you will NEVER break a sterling OR a Dana 70 shaft with a welded carrier! EVER!
i challenege you to find someone who has ever busted a sterling axle shaft b/c of a welded carrier (and not b/c of your buddy's shoddy welding job either!)... and not a buddy of a buddy of a friends sister. try to find somebody.... i dare ya!
-cutts-
Old Jun 24, 2007 | 12:40 AM
82F100SWB's Avatar
82F100SWB
Hell, I've been known to gross 20K lbs with my diesel, it's rear is welded, and I run 33's... Never, ever had an issue other than the axle to hub bolts coming loose on the pass. side. Poor tires take a beating with the GN attached tho, only pulled it twice, I stick to a bumper pull because of that....
Old Jun 24, 2007 | 02:40 AM
wizzard351's Avatar
wizzard351
some folks are just scared of a weld or spooled rearend. just let'em spend the big bucks to do the same thing in a different way then they'll learn an expencive leson. the only thing that will happen with a welded/spooled rearend is a lil more tire ware thats all. ive got about 2000miles on mine now and probly over 40000 on a previous trucks spooled,just a few more tires with no probelms.if ya know how to drive it isnt that big of a deal
Old Jun 25, 2007 | 01:43 PM
Thomsen's Avatar
Thomsen
Go ahead and weld it...as fishy and kubota said, you will NOT break the sterling rear if the welding is done right. Now a dana 60 rear is a different story...
Old Jun 25, 2007 | 04:36 PM
oneofakind97's Avatar
oneofakind97
wait...why would a dana 60 be a different story?
and i always thought my truck, 1997 oldbodystyle f350 had dana 60's front and back, so how do i tell if its a sterling or not. maybe ive just been misinformed this whole time.
Old Jun 25, 2007 | 05:20 PM
RawPower's Avatar
RawPower
Dana 60 rears aren't near as strong as a 10.25
No, you have a D60 front, 10.25" rear
Old Jun 26, 2007 | 12:11 AM
Soilman's Avatar
Soilman
OK, yall have convinced me to go ahead and weld my 10.5, saves the locker cost for the rear.
79f100six, don't weld the front Dana 44 it will not last!!! Years back I ran welded diffs front and back on my 1977 F150. Kept one hub unlocked to make turns! I got real good at replaceing axles, u-joints, tie rods and carriers. I would reweld the new one and do it again. But I was young and dumb with 500+hp. I have stayed away from solid diffs for that reason since.
Old Jun 26, 2007 | 05:32 AM
KubotaOrange76
60 rears arent much stronger than a dana 44...weak 30 spline 1.3" shafts and smaller 9.75" ring gear, compared to a sterling 10.25" ring gear and 1.5" 35 spline shafts..
they started putting the sterling in the rear of pickups in about 1985.5
Old Jun 26, 2007 | 11:56 AM
fishmanndotcom
Dana 60's and 70's have oil plugs in the cover. sterlings have plugs on the side of the housing on the front side just above the pinion centerline.
everyone thinks D60's are so great but they suck. biggest thing they have going for them is a decent aftermarket. BUT if you get a sterling to begin with you will NEVER break it so you wont have to worry
b/c you will NEVER break a sterling, you gotta be crazy/stupid/drunk/apathetic to break a sterling.
just gotta make sure that your 'buddies' ( ) weld it right! i'd be willing to bet 'they' just welded a couple of spots b/t the spiders and side gears and then when the weld broke (due to lack of proper cleaning and still having oil residue on everything) THEN the carrier bound up and broke. however i SERIOUSLY doubt it took out an axleshaft!
-cutts-
Old Jun 27, 2007 | 01:29 PM
Thomsen's Avatar
Thomsen
Yeah that is what I was getting at, the rear 60 is not very strong.
Old Jun 28, 2007 | 07:13 PM
  #28
KubotaOrange76
i broke a rear 60 shaft in the sand with 39 boggers and a weak 460 pulling someone out, they are weak
Old Jun 28, 2007 | 10:43 PM
  #29
fishmanndotcom
lol
OR you could be ghey and lift truck with your steering and call it technical
-cutts-
Old Jun 29, 2007 | 05:59 AM
  #30
KubotaOrange76
i broke a 37 spline axle in my dodge the other day getting on the interstate in overdrive...those on ramps are freakin hard on drivetrain parts
buttz
1997 - 2003 F150
Jun 15, 2015 04:08 PM
betsy_vavavoom
Aug 1, 2010 10:43 AM
DesertStorm
Offroad & 4x4
Feb 9, 2008 08:38 PM
dannunz
15
Feb 27, 2007 10:45 PM
ClatonK
Offroad & 4x4
Oct 3, 2005 09:00 AM
