Anyone ever drive a spooled or welded diff in the snow and ice?
Anyone ever drive a spooled or welded diff in the snow and ice? I am thinking of locking my F250 for nearly all off road and storm weather. My only concern is winter roads. I am told by a few guys that it will be ok if I drive slow and careful. And I should not fish tail if I keep of the gas. Any coments from those that have actual experience with a spool or welded diff.
Thanks,
Clayton
Thanks,
Clayton
I really wouldn't recommend it for winter weather, especially if you are going to use it for a daily driver and have both ended welded.
I've driven with the rear end locked in the winter, can lead to a lot of funny stuff (fishtailing, rear end kicking out of turns, etc). a spool or a locker will make you want to push through your turns, especially on ice.
not a good thing, especially in the front.
The problem with a welded carrier/ locker on ice is that when one tire breaks free it will actually break the other tire free and the truck slips sideways. even an open rear end with one tire spinning and one tire rolling is better because the rolling tire has SOME traction to keep the truck strait.
when you turn a truck with a fully locked axle on a surface with traction the tire on the inside of the turn acts as a pivot and the outer tire skips a little to make up the extra distance. When that inner tire doesn't have any traction the whole truck just shifts in whatever direction its inertia sends it.
Obscure69
10-21-2016 12:30 PM
KJKozak2
03-19-2002 10:53 AM
