Does someone out there have a list for what parts are good for both the older and the newer powerstrokes? I'm mostly interested in the suspension right now, but I know nuermous other parts will interchange. I heard the leafs on the superduties are a little longer thans ours. Does any body know about the shocks? Do they interchange our is it a differnet set up? Thanks
Rear springs are close to the same other than the bolt hole sizes. Front springs are longer and require fab work(alot) to make them fit. Shock well I have run SD shock on the front of my OBS truck. They are close enough to fit but one end needs a sleeve put in the bushing. the rears aren't close enough of to fit safely.
the rears wont work? i've been contemplating a SD ft and rear swap and have been meticulosly measuring mine while next to a buddies 03 and i really think they are a direct swap, the only thing that i have come up with is the tie rod holes size, the drive shaft connections are smaller on ours, other than that its a green lite, i havent measured the pinion flange on the 10.5 yet but i know the 10.25 and 10.5 carriers are a direct swap. i am hoping they are interchangable so i can swap my flange to the sd's case and re-use my shaft in the rear, the ft i will get a custom u-joint to adapt to the dana 60
