360 to 390
Old Sep 7, 2003 | 09:16 PM
1970 F-250's Avatar
1970 F-250
360 to 390
Does anyone know what all parts, must be changed to convert a 360 to 390. I thought I heard that the blocks are identical and a lot of parts are interchangeable.
Old Sep 8, 2003 | 12:36 AM
d44hd's Avatar
d44hd
360 to 390
crank, rods, and pistons...everything else is the same.........d44hd
Old Sep 8, 2003 | 10:52 AM
Nick_Sand's Avatar
Nick_Sand
360 to 390
Just the Crank and rods. a 360 is a 390 block with a 352 stroke. So the bore is already right, no need for pistons.
Nick Sand
1971 & 1967 F100 390 C6
if you are looking for ANY parts, E-mail me.
Old Sep 8, 2003 | 11:17 AM
rusty70f100's Avatar
rusty70f100
360 to 390
Not exactly. Some 360's used full skirt pistons, which will not clear the crank counterweights on a 390 crank.
Old Sep 10, 2003 | 02:57 PM
simenad's Avatar
simenad
360 to 390
360's, I'm told, have thinner walls
Old Sep 10, 2003 | 03:19 PM
rusty70f100
360 to 390
You were told wrong. 360's and 390's use identical blocks.
Old Sep 10, 2003 | 05:49 PM
willowbilly3's Avatar
willowbilly3
360 to 390
Ok so you are saying then that the deck height is the same on both the 360 and 390 pistons? Then the rod length is all that is different? I had actually never done this and told someone that the pistons were different and the rods were the same. oops!
Old Sep 10, 2003 | 10:20 PM
rusty70f100
360 to 390
No, the compression height of 360 and 390 pistons are different. 360 pistons have a compression height of 1.776, and 390 pistons have a compression height of 1.680. If you use 360 pistons in a 390 you should have .016 deck clearance, so it should work. The only thing is, some 360s were built with 390 pistons from the factory, so the only way to know which ones you have is to measure them. In any case, if you have the slipperier skirt pistons, as opposed to the full skirt pistons, they should work. Just 360 pistons will develop more compression than the 390 pistons.
Old Sep 11, 2003 | 03:03 AM
willowbilly3
360 to 390
Thanks rusty. I don't know the formula but it seems that .96 would be a lot more compression. A reconditioned rod would take care of a little bit of it. Of course the whole point is a bit lost when you consider that most engines that are apart probably need rebuild and bored out which would required new pistons anyway.
Are there aftermarket pistons that allow you to use the 360 rods on the 390 crank? It seems like that would make the swap a little cheaper.
Also I would offer this bit of advice. Try to get the earlier block. The last 2 or 3 years of the FE they had too many reliability problems which seemed to be related to the alloy in the block and heads.
Old Sep 11, 2003 | 09:41 AM
buzzard's Avatar
buzzard
360 to 390
I've heard that one can use the longer rods without problems (except a higher CR), however, they are not nearly as "beefy" as the 390, 428, 410, etc. rods so by trying to save $50, you'll be handicapping your engine.
Old Nov 14, 2003 | 07:07 AM
emtabmm's Avatar
emtabmm
Come on, it can"t be that easy.....
Old Nov 14, 2003 | 04:23 PM
buzzard's Avatar
buzzard
Oh, but it is.
Old Nov 17, 2003 | 06:15 AM
emtabmm's Avatar
emtabmm
So let me get this straight, 390 crank and rods, short skirt pistons and voila, presto - 360=390?
Old Nov 17, 2003 | 06:58 AM
Ratsmoker's Avatar
Ratsmoker
Exactly. I used a 390 crank, rods and TRW L2291F60 pistons on my conversion. The 360 rods are a waste. You are only going from a 1.71 rod/stroke ratio to a 1.73 ratio. You won't see that difference on the dyno no matter how hard you look. The 390 rod is much beefier. The blocks are 100% identical.
Old Nov 17, 2003 | 07:01 AM
emtabmm's Avatar
emtabmm
WOW, thanks, I've got a 360 with a stuck ring (hasn't been run in 2 years), so I am going in to replace rings, won't be much of anything to replace these parts while I'm there....
