?? Positive - Negative Ground Coils ??
Old Jun 19, 2007 | 05:29 PM
John W Cina's Avatar
John W Cina
Arrow ?? Positive - Negative Ground Coils ??
I have some coils I wanted to use on either the Model A or My 1947 Flatty V8 Pickup.
The Coils have three terminals -- besides the Hi Voltage.
They are marked; ( + ) , ( - ) , and ( DIST ) !
I get 0.25 ohms between the + and - terminals.
I get 16.20 Kohms Between High Voltage and ( + ) or ( - ) .
These sound okay.
BUT THE TERMINAL MARKED ( DIST ) seems to measure open to everything !!!!!!!
What may the " DIST " TERMINAL before ????????? Anyone KNOW ???
I may cut one open ---------- good ole Auction fines !!!!!!
Old Jun 19, 2007 | 06:47 PM
John W Cina
I'm working at confusing my self '''''''''''''''
I answered one question ---------- I cut open one of my NEW - auction coils ------- and the terminal marked " DIST " is going no where ----- which my infinite resistance reading said.......
Now the terminal marked " + " is the common one between the low voltage primary winding and the auto transformer - Hi Voltage secondary ---------------------------------------
Sooooooooooooo in wiring up for ignition I could either use points to switch the ground point either at the + or - terminal -- thereby getting the proper NEGATIVE High Voltage Pulse to the Plugs ------------Hummmmmmmmmmmmmmmm
which is the best way ????????????
I've seen other discussions on this topic ----but ??????????????
Thanks ??? John gettin ready for 'back tp fifties'
Old Jun 19, 2007 | 09:54 PM
Franklin2's Avatar
Franklin2
Of course if you are running 12 volt negative ground, you hook the points the negative, and the ignition switch and ballast resistor to the +.
I seem to remember burning up my original coil on my 53 f100(when it was original 6v pos ground) and I took a regular coil and hooked the points to the + and the hot wire from the key to the negative, and it worked fine.
sixofspades
33
Dec 25, 2023 10:28 PM
Shep1
41
Oct 7, 2016 08:56 AM
dnkensinger
20
May 29, 2016 06:22 PM
wahlturfcare
Feb 11, 2015 05:24 PM
nametrux
Jan 5, 2003 01:30 PM
