Weird Tranny Problem
Old Jun 19, 2007 | 10:17 AM
jersan's Avatar
jersan
Smile Weird Tranny Problem
MY 92 Explorer ran a little bit hot, so I stopped to see what the problem was.I saw the water pump was dripping,so I added water and started to back up and for some reason ,I didnt have reverse.I put it in drive ,everythings fine.So now I call and get a ride to get a water pump.I install the water pump and check reverse,it works perfect,but now I dont any forward gears.What Gives???
Old Jun 25, 2007 | 03:26 PM
jersan's Avatar
jersan
Someone suggested that it might be in the computer,but how did I mess up the computer by changing my water pump???
Old Jun 25, 2007 | 03:41 PM
Backin72's Avatar
Backin72
Check the level and condition of your tranny fluid. If low, top it off. If it's dark and smells burnt, get it flushed. The latter is not a good sign but you may get lucky.
Old Jun 25, 2007 | 03:46 PM
jersan's Avatar
jersan
Thanks alot for your reply,I'll give it a shot when I get home.
Old Jun 25, 2007 | 09:46 PM
aagitch's Avatar
aagitch
definitely is most likely unrelated to the water pump problem.
Old Jun 27, 2007 | 11:10 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Is it possible that the fluid was heated up in the radiator since there wasn't enough fluid circulating from the engine. Maybe it is possible for the fluid to get hot enough to cause the transmission to slip or something similar? Just a guess, may be way off.
bigjr2
All Things Towing
16
May 18, 2013 08:45 AM
cjetmech
Mar 7, 2013 11:09 AM
Foxhound^
Oct 16, 2012 01:43 PM
Freakazoid!
Dec 6, 2007 02:01 PM
dustinova
Nov 18, 2007 10:16 AM
