Sponsored by: Real Truck
Lug nut difference?
Old Jun 18, 2007 | 08:21 PM
07250psd's Avatar
07250psd
Lug nut difference?
Guys, I currently have the factory steel (chrome covered) wheels on my new 07 f250. I am wanting to upgrade to a set of 08 take-offs polished alum. wheels. Do I need new lug nuts or are they all the same?? The plastic caps are the same as mine which I will use.
Any thoughts on this??
Thanks !!
Old Jun 19, 2007 | 08:50 AM
07250psd's Avatar
07250psd
Anybody ????????
Old Jun 19, 2007 | 10:56 AM
redford's Avatar
redford
FTE Leadership Emeritus
I would ask your local service department just to be sure. They should be able to compare part numbers.
It SHOULD be the same lug nut, but I think the problem is we (members) haven't seen enough '08s yet to be able to answer the question with 100% accuracy.
Old Jun 19, 2007 | 04:16 PM
07250psd's Avatar
07250psd
Thanks, I guess that the better question is,,, will the lug nut that come with steel wheels work on the alum. without any damage??
I know in the past on a ranger, I had to change them is the only reason I ask.
Thanks again !!!
Old Jun 19, 2007 | 07:29 PM
skunk250's Avatar
skunk250
I actually just replaced my steel wheels on my 07 f250 with some aluminum(aftermarket) and Yes I did have to replace the lugs.
The stock wheels used flat seat lugs and the aluminum uses conical seat type.
It is my understanding that if you use the incorrect seat type on the wheel it can lead to possible damage or lugs that loosens on their own while driving. Not good.
Old Jun 19, 2007 | 07:59 PM
krewat's Avatar
krewat
Flat nuts are used with hub-centric rims (center hole aligns the wheel to the hub), conical nuts are used on lug-centric rims (lugs center the wheel to the hub).
Superduty's are hub-centric. If you are comparing stock-to-stock, the alloy rims SHOULD be hub-centric and use a somewhat similar lug-nut. But with alloys, I really don't know personally.
Aftermarket, who knows...
Old Jun 20, 2007 | 09:52 AM
07250psd's Avatar
07250psd
Thanks guys, I can call the dealer, but would rather take advise from someone who did the same thing I want to. I would think they are the same, with different tourque level but Ill research that too !!!! Thanks again !!!
Old Jun 20, 2007 | 10:46 AM
NOCO77's Avatar
NOCO77
It shouldn't be a different torque level - that is not determined by the wheel. It is based upon the stud size, which is unchanged.
cmcstotts
2009 - 2014 F150
Aug 29, 2013 08:56 PM
Brian429
2004 - 2008 F150
Apr 17, 2012 01:57 PM
scotjonscot
Jul 14, 2009 05:19 PM
jlalanas
May 13, 2009 06:20 PM
fhartell
Aug 27, 2004 07:59 PM
