Checking RABS codes
Old Jun 18, 2007 | 06:15 PM
vaman4215's Avatar
vaman4215
Checking RABS codes
Where is the connenctor at to ground and check the rear ABS codes located at??? I just put on new rear shoes, replaced the broken spring and keeper and attached the adjuster cable that was dangling, now to see what the codes are and clear them and see if anything re-appears..Now have good rear brakes with no locking up of either wheel...Once the ocdes are displayed will it clear the codes and turn the yellow light off???
Old Jun 18, 2007 | 06:19 PM
quicklook2's Avatar
quicklook2
disconnect the battery for 10 minutes or so.
Old Jun 18, 2007 | 10:37 PM
bustedflush's Avatar
bustedflush
on my 90 f250 its a wire that dangles down near the brake pedal with a little grey clip on the end, I think it's black and orange wire.
Old Jun 19, 2007 | 06:09 PM
EPNCSU2006's Avatar
EPNCSU2006
^ yep. Momentarily ground that black/orange wire and the light should flash the codes. The ABS computer resets each time you turn off the truck, so disconnecting the battery or doing anything else to re-set the codes won't do anything more than simply turning off the ignition switch. If you still have the light, you still have a problem.
amdriven2liv
Nov 18, 2013 10:35 PM
V8Ranger302
Nov 7, 2010 03:39 AM
trapperack
Dec 24, 2009 04:35 PM
trapperack
2009 - 2014 F150
Dec 22, 2009 04:57 PM
