Offroad & 4x4
4WD stuck in?
Old Jun 18, 2007 | 01:55 PM
chum23's Avatar
chum23
4WD stuck in?
I have a 97 F250 HD and recently put it in 4wd to get out of a ditch. Ever since the truck is acting like it is stuck in 4WD. I checked the hubs and they are not locked in, I also put it in and out of 4wd a few times to see if I could get it to stop. I notice a skipping the most when I'm turning hard right or left or in reverse turning hard right or left. I recently serviced the transfer case, front and rear diffs. At this point it seems that I am hearing noises from both the front and rear end. Anybody have any thoughts/suggestions?
Old Jun 18, 2007 | 10:03 PM
zpmps2's Avatar
zpmps2
Talking
i dont know nothing about the new trucks, but ive heard that if you put it in 4 hi, with the hubs locked and then go in reverse and switch it to 2 hi going about 5 mph, and then get out and unlock the hubs, it will work, atleast thats what ive heard the chevy's guys did when they had problems w/ their trucks
Old Jun 18, 2007 | 10:14 PM
captain p4's Avatar
captain p4
Does it have manual locking hubs and floor shifter?
Is the rear end a limited slip unit? If so, did you put limited slip additive in the diff?
Old Jun 19, 2007 | 08:00 AM
chum23's Avatar
chum23
It has manual locking. The rear end is limited slip and I put the Lucas gear oil with the additive already in it.
Old Jun 19, 2007 | 08:10 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
do you shift in and out of 4x4 with a lever or buttonS?
Old Jun 19, 2007 | 08:20 AM
chum23's Avatar
chum23
With a lever
Old Jun 19, 2007 | 08:36 AM
captain p4's Avatar
captain p4
Well if the hubs are unlocked and the floor shifted is out of 4wd its not stuck in.
Maybe try more additive in the gear oil?
Old Jun 19, 2007 | 08:53 AM
chum23's Avatar
chum23
can too much gear oil be a bad thing?
Old Jun 19, 2007 | 10:42 AM
captain p4's Avatar
captain p4
too much of the additive would cause your LS to not work as well, possibly not at all. There's a thin line you have to find between comfort and functionality with it.
Old Jun 19, 2007 | 02:09 PM
KubotaOrange76
are you sure you have it out of 4x4?
ironandsteel
Dec 10, 2014 03:31 PM
5.0 Heaven
1978 - 1996 Big Bronco
Feb 12, 2013 07:21 AM
tschrubb
May 6, 2012 09:06 AM
smashclash
Jan 30, 2011 11:51 AM
