CCV Collection Trap
Old Jun 18, 2007 | 08:42 AM
F250_'s Avatar
F250_
CCV Collection Trap
After 4500 miles since rerouting my CCV in early April, I finally pulled the plug on the trap and drained out about 2-3 ounces of oily liquid. I can only estimate how much was there because the bucket my son handed me to use already had a slight amount of oil in the bottom of it from when I sampled my oil for Blackstone, and I didn't see the oil in it before draining the CCV trap.
The total amount from the bucket was 4 ounces. I am sure that there was at least 1 ounce already in the bucket, but not sure of the exact amount. I transfered the catch from the bucket to a clear pint jar so I can see how much non-oil condensate is there once it all separates over the next several days.
Conclusion, I going to replace my screw in plug in the trap with a short PVC fitting with a valve in it to make the whole thing easier to drain.
Old Jun 18, 2007 | 09:02 AM
Izzy351's Avatar
Izzy351
Do you have your CCV hose ran straight down or up over the brake booster? Just curious...
Joe
Old Jun 18, 2007 | 10:24 AM
F250_'s Avatar
F250_
I have it run up over the master cylinder, so what I am catching is definitely a combination of condensed vapors and/or occassional droplets of liquid carryover.
I keep meaning to take shots of my install and put them in my gallery, but just haven't taken the time to do it yet.
Old Jun 18, 2007 | 11:48 AM
Izzy351's Avatar
Izzy351
Okay, so that means I must be getting some out of there as well, but it most be so little that it's just shoots out when the engine is under load, because I never see anything under the end of the hose after parking or even idling. And I have a little smoke, but not much to speak of. Since I had oily boots, it must've been coming out of there...
Joe
Old Jun 18, 2007 | 11:51 AM
F250_'s Avatar
F250_
Probably blowing out at higher velocities when you're traveling down the road. I put a coarse scothbrite pad as a "mist eliminator" in the discharge of my trap, so I should be catching all entrained moisture droplets whether they're oil or some other condensed liquid.
littleapple
6.7L Power Stroke Diesel
Nov 10, 2015 09:12 AM
King-bRanch
Apr 14, 2015 07:32 PM
miker67
Jan 6, 2015 06:48 PM
SpartanDieselTech
Apr 10, 2014 09:41 PM
Splatts
13
Mar 23, 2014 07:25 AM
