Hey all, I have a question. I just brought home the new car trailer and need some knowledge. I have decided I would like to go with tow straps instead of chains when I haul the car around. If I were using chains, this qustion would be unnecessary. Buy chains with hooks, buy binders, go towing! But, since I want straps, here goes"
When they rate straps they state a "working load limit" and "breaking strength".
Is the difference as obvious as it looks? ie.:
I can strap my car down with (2) 5,000# straps in front and (2) at the rear. That means they will each "hold" 5,000 lbs right? So while the idea of two at each end is for even holding power and stability, does the 5k indicate one can handle the load in the event one loosens or the car shifts? Of course if the car shifts I most likely have other issues!
-----AND-----
The 10,000 "break" is if I am in an accident, they will hold up to 10,000 lbs of sudden force?
I use 4 straps I run the front straight and cross the back. I have stake pockets so I use axle straps around the pockets, the axle straps have a protective sleeve. I just ordered some replacement stuff from Macs custom ties downs and they are better quality then the ones I was using. I try to have a couple of extra wraps and tie downs.
In the fwiw department, it is not a bad idea to have a 3/8 chain for a backup wrapped around an axle and around the frame of the trailer to make sure the vehicle carried stays with the trailer in a disaster.
I've broken 5000lb straps before... several of them. I'd be a little concerned about using straps myself, chains are pretty reasonably priced, why not just splurge?
You've busted several 5000 lbs. straps hauling 2500 lbs. cars?
Not to offend, but that is just about impossible if the car was tied down correctly.
Not, not tying cars, but I have broken them doing things that shouldn't have overloaded them. I'm just saying I don't trust straps anymore, and for the price chains aren't THAT much more expensive.
It's not cost that is steering me away from chains. It's the ease of use that straps confer. No binders, and the ability to use four straps instead of two big ole chains.
Some states require a separate tie downs at each corner of the vehicle too, so even if you had a BIG chain you would need two at each end. Also if you go with the straps make sure you get the ones with the safety clips on the hooks , that way if the straps get some slack they can't come unhooked.
