Momma wants a concrete pad (for a gazebo) in the centre of the lawn, with some sidewalks leading to/from it. How thick of concrete and what strength ( sand/gravel ratio per bag of concrete) do I need?
How big are you making it? You may want to consider getting the concrete delivered. The concrete place will mix it up correctly. Doing it by the bag for anything more than 2 cubic yards is a PITA.
How much do you need? Take the length (times) width (times) height and divide by 27 to get total cubic yards. Make sure you convert your height measurement to feet. 4" is .333 feet.
I live 10 miles from town and only need about 2 yds. I don't think they'd be to fussy about sending a truck out; unless I paid through the nose for it.
I've got a little mixer here; so not to scared to mix up that much. Should I use a mesh? I'm only going about 12' X 12'.
It's going to heave up some of you don't take the earth down to something without moisture in it.
You don't have to worry about lateral expansion blockage.
An easier way to figure is length times width divided by 81. Thats for a 4 inch slab. example I want to pour a pad in front of my shop 16x12. That equals 192 square ft. Divide 192 by 81 that equals 2.370 yards . So I will order 2 and 1/2 yards and if I have all my depths right I should have a little left over. Thats the way I learned to figure concrete. If I had to figure for 8 inches I would double the amount if I needed it for a 6 inch slab I would go 1.5 times the amount.
Thanks for the info Dennis. I'm just outside of Prince Albert; Gateway to the beautiful North. I should also mention that I have my own little sand pit just on the other side of trees by the house. This is influencing my choice also.
I'd go with at least 5" perimeter and 4" pad with a minimum of 25Mpa- 32Mpa with 6% Air and C-2 exposure with .70 W\C ( water to cement ratio) in my location ( Ontario, Canada), could also request fiber mesh to be batched in at the plant or added on site to load, versus cutting and fitting steel mesh. Depending on location will determine your exposure rating.. but you will definitely want air entrainment in it. Find an independent supplier rather than the Big companies. Dufferin, Lefarge or CBM, they will charge you top dollar for concrete and delivery, with a minimum 3 meter underload charge. www.mpaq.com has a free concrete calculator for meters and yards and associated costs.
Check with the local code authorities for the depth of foundation and reinforcement required under the proposed structure. It would not be cool to have Momma conked on the head by a 2x4 (50x100mm) because the structure was being pulled apart by frost heave...
Also another option if it's available in your area is a " Elkin Mobile Mixer ". for a backyard pour these are ideal.. These mobile mixers carry Portland, sand, stone and water onboard and batch only what is needed for the job onsite, avoiding shortages or leftover waste.
Seems to be a powder war on the rise around here .. our Ready-Mix division just got bought out by Essroc they paid big dollars to get into the market in this area, although they have shared the market in Toronto area for awhile in a joint adventure with Lafarge to create = Innocon ..... seems the Independents are a dying breed.
