Horn replacement
Old Jun 15, 2007 | 10:17 AM
RangerPilot's Avatar
RangerPilot
Horn replacement
Suggestions on new horns? Mine is apparently very much dead...went to honk at a buddy day before yesterday and got a click. That was it. Just a click.
Pulled the horn last night (that was fun), it's dead.
So...suggestions?
Old Jun 15, 2007 | 10:25 AM
pgw85706's Avatar
pgw85706
Here is an idea that came around recently!!!
http://www.youtube.com/watch?v=TiWNw0A1Ijg
Old Jun 15, 2007 | 02:52 PM
dono's Avatar
dono
Gone but not forgotten.
So...suggestions?
I assume you put power to directly to the horn and it will not blow, and you see power at the horn when the button is pushed. Used horns are pretty cheap and there are lots of aftermarket horns around. I put a toggle switch on my dash so that the stock horn blows in one position and my OOOHGA horn blows in the other Good luck.
Old Jun 15, 2007 | 03:11 PM
CMOS's Avatar
CMOS
I have a realted question. IMO, my horn stinks. It doesn't seem loud enough for anyone to even hear if/when I need to use it.
Are all Ranger horns winpy like this or is mine weak?
What are some options out there for something that is louder, but won't kill the bank account?
Thanks,
CMOS
Old Jun 15, 2007 | 03:12 PM
fordboy_52's Avatar
fordboy_52
most auto parts stores will carry both the low and high pitched horn. my dads f-250 had one of each when i replaced them
Matt
Old Jun 15, 2007 | 03:15 PM
CMOS's Avatar
CMOS
Matt
Rangers have the dual horn tone set-up?
CMOS
Old Jun 15, 2007 | 03:17 PM
fordboy_52's Avatar
fordboy_52
im not sure, i dont know where mine is exactly :P
Matt
Old Jun 15, 2007 | 03:20 PM
CMOS's Avatar
CMOS
I just popped my hood - single horn setup. Would take about 30 seconds to remove. Wimpy little thing.
Aftermarket horns available that are louder?
CMOS
Old Jun 15, 2007 | 05:05 PM
RangerPilot
Seems they used a single horn up until the mid 90s, then went to dual, and apparently by '04 were back with singles again.
And Oooga...where can I get one? Sounds like fun.
And yes, I removed it, checked for power at the wires, and directly tried to run it off multiple 12V batteries. Nothing.
Old Jun 15, 2007 | 08:56 PM
dono's Avatar
dono
Ebay has them (see item # 260128192801). They are a fun horn, and at 110db will get some attention.
Old Jun 15, 2007 | 09:02 PM
RangerPilot
I'ma watch that for a few days and probably end up picking it up when I get back in town Monday. Thanks Dono.
Old Jun 16, 2007 | 03:27 PM
dono's Avatar
dono
Delete post
Old Jun 16, 2007 | 07:40 PM
pmetro1's Avatar
pmetro1
if your familar with JC Whitney, they have a good selection of horns, the 91 ranger has dual horns i think they are FIAMM horns , some types have a small adjustment screw on they so you can tune them to hi-lo pitch. It basiclly varies the gap of the buzzer Other than checking them with 12 v power, you can check the resistance, as they are a vibrating device they could get stuck and just click. I guess you should blow your own horn once an awhile to keep them working !!!!!
Old Jun 17, 2007 | 06:46 PM
racsan's Avatar
racsan
i got a dixie horn setup from jc whitney back in '89 and it still works. put it in my ranger after it hadnt been used in years. still works, and loud. only thing better would be the "freight train" horn setup.
oft
13
Oct 17, 2014 08:18 PM
Duckmang
Jul 28, 2013 11:40 PM
garydmundy
Dec 18, 2012 03:14 PM
johnboggs21
Sep 8, 2009 08:57 PM
jdmak68
1978 - 1996 Big Bronco
Dec 13, 2007 09:09 AM
