Dtc P1211?
Old 06-14-2007, 11:31 PM
Mr. Bob's Avatar
Mr. Bob
Mr. Bob is offline
Dtc P1211?
Hey Guys,
With my DP tuners chip, on both the 80 econo and the 120 race, if I get on the throtte I set a P1211 code...
Is this that my HPOP cant keep up???
Thanks guys!
Bob
Old 06-14-2007, 11:33 PM
VQ2Fast4U's Avatar
VQ2Fast4U
VQ2Fast4U is offline
Id have to say yes.
Old 06-14-2007, 11:55 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Powerstrokedlariat is offline
I think that is a really common code for a chipped truck, not sure if your hpop cant keep up, I just think the pressure is above the desired range.
Old 06-15-2007, 10:18 AM
Action4478's Avatar
Action4478
Action4478 is offline
Fuel pressure can set 1211 also...
Old 06-15-2007, 11:44 AM
Pocket's Avatar
Pocket
Pocket is offline
If you are setting the code at WOT, then the oil pressure is BELOW desired pressure, setting off the P1211. You can monitor this with AE or another live data monitoring tool and watch as the high oil pressure drops, usually between 1900-2200 psi. Even the 80 Econo setting calls for more pressure than that when you have the pedal to the floor.
Oh, and fuel pressure cannot cause the P1211, it's only oil pressure and it's measured from the ICP sensor. A demand for more fuel from a chip will cause oil pressure to drop because more fuel requires more oil, and many stock HPOP's can't meet the demand.
Old 06-15-2007, 12:46 PM
Action4478's Avatar
Action4478
From the repair CD
KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
  • DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
  • Possible causes:
    • incorrect oil or viscosity
    • poor oil quality
    • gel fuel/no fuel
    • low fuel pressure
    • damaged IPR valve
    • high-pressure oil system leak
    • damaged high-pressure oil pump
    • damaged PCM
  • Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
lstitt
Australia Chapter
12-22-2015 02:43 AM
sudsmcduff
11-14-2015 06:10 PM
bcarless
11-09-2015 05:35 AM
viperbluelx
16
12-05-2008 12:45 PM
Fullcrew7.3
03-07-2008 09:07 AM
Quick Reply: Dtc P1211?
