05 Excursion 6.0 advise
Old Jun 13, 2007 | 09:51 PM
97REDPSD's Avatar
97REDPSD
Question 05 Excursion 6.0 advise
This weekend I will be checkin out an 05 Excursion with a 6.0 need some kind of advise on what to look for in the engine and if the Excursion's have had any kind of problems with the engines with model yr 2005.
Thanks
Old Jun 13, 2007 | 10:21 PM
6L PWR's Avatar
6L PWR
Thanks
Ask for an Oasis report or get the VIN and post in https://www.ford-trucks.com/forums/6...st-thread.html asking for an Oasis report. This report will list all the service visits at the Ford dealerships so you'll see any warranty work that was done. Lots of warranty claims = not so good engine.
Old Jun 14, 2007 | 12:47 AM
Btravelen's Avatar
Btravelen
An '05 Ex uses the '04 engine. Even my 08/05 built Ex with 08/05 built engine is an '04 6.0L.
Old Jun 14, 2007 | 07:06 AM
97REDPSD's Avatar
97REDPSD
thanks guys I will ask for a report. So it has a 04 6.0 that still good right.
Old Jun 14, 2007 | 12:09 PM
Btravelen's Avatar
Btravelen
Mines been great so far. 20K miles. Besides the hanging drip.....
Old Jun 14, 2007 | 05:20 PM
RoyC's Avatar
RoyC
All Job#2 2005 X's have the 2005 engine. Job #2 date was sometime in mid to late Jan 2005.
RoyC
Old Jun 14, 2007 | 09:45 PM
Btravelen's Avatar
Btravelen
Check again. Your sticker on the engine may say '2005' but it's a 'carryover' '04. 560 ft/lbs, not 570.
Check out page 2 of the 2005 update pdf. It outlines all of the updates the Excursion didn't get.
http://www.forddoctorsdts.com/public...ble%20Book.pdf
Take Care
Old Jun 15, 2007 | 02:50 AM
97REDPSD's Avatar
97REDPSD
Thanks Guys For Help
Old Jun 15, 2007 | 01:50 PM
RoyC's Avatar
RoyC
Take Care
Well, I have the document and per page two it states that "Excursion vehicles carryover the 2004 MY engine for the first part of the 2005 MY". The EGR throttle is a carryover BUT my engine does not have it. I have the new fuel supply line trap, with banjo bolt and two copper washers. Also per page 5 I have the new front cover with the repositioned coolant returns for the heater and radiator.
Per your document, the fuel supply line change and front cover change are NOT interchangeable with 2003 or 2004 MY engines.
Maybe I have a one of a kind!
RoyC
Old Jun 15, 2007 | 02:04 PM
msgtg's Avatar
msgtg
Once you make the decision, call Ford and ask for the build sheet so you can see when and what was original on the X.
Old Jun 15, 2007 | 10:18 PM
Btravelen's Avatar
Btravelen
Per your document, the fuel supply line change and front cover change are NOT interchangeable with 2003 or 2004 MY engines. Maybe I have a one of a kind!
RoyC
My apologies RoyC. You are correct. I just came in from rechecking my 08/05 Huntsville built 6.0L and sure enough, I have the '05 fuel trap, front cover, and high pressure pump with revised IPR valve up on top. I assume the rest of the upgrades are there, also. The cert. sticker still states 560 ft/lbs of torque, though. 10 ft/lbs must be in the program?
Do you have a H'ville or Indy built 6.0L?
Take Care
Old Jun 16, 2007 | 07:57 AM
RoyC's Avatar
RoyC
My engine was built in Huntsville on 1/03/05. Truck was assembled 2/08/05.
It is nice to know you have all of the 05 improvements.
RoyC
Gmcbuffalo
Sep 25, 2012 09:24 PM
Grahams
May 24, 2010 01:39 PM
jdw1
Jul 30, 2009 03:57 PM
The Big Bad X
Jan 24, 2009 01:15 AM
6.0king
Mar 1, 2005 12:06 AM
