Speedo cable removal?
Old Jun 13, 2007 | 08:33 PM
Andy's '79's Avatar
Andy's '79
How does the speedo cable come off of the cluster?I'm trying to get it out so I can clean the connections around the little light bulbs and clean it up as well.I have taken the two 1/4" bolts loose that are on the top and bottom but I still cannot get it out and I don't want to break anything. '79 F-150
Old Jun 13, 2007 | 08:36 PM
uncle2abc's Avatar
uncle2abc
There is a plastic clip that hold the cable to the back of the gage cluster. After you remove the small screws holding in the cluster you can usually pull in forward just enough to reach back there and pop the clip off.
Old Jun 13, 2007 | 09:01 PM
Andy's '79's Avatar
Andy's '79
I was scared of breaking the clip,which way does it come off
Old Jun 13, 2007 | 09:30 PM
rusty7983's Avatar
rusty7983
there is a square side to the clip. it needs to be pressed in and the cable slips off.
Old Jun 13, 2007 | 09:36 PM
uncle2abc's Avatar
uncle2abc
I don't really remember how I got it loose. If you can't figure it out let me know and I'll look at the project truck in the garage and try to figure out how I did it.
Old Jun 13, 2007 | 10:25 PM
Jermafenser's Avatar
Jermafenser
This question has been posted several times.
Do a search, and you will also get illustrations on how to remove the cable.
Old Jun 13, 2007 | 11:49 PM
Mil1ion's Avatar
Mil1ion
Press the movable plastic part in at the same time pulling the connector out and away from the speedo housing.
Old Jun 14, 2007 | 04:47 PM
trinogt's Avatar
trinogt
Here is how you do it:
Press the flat side of the vinyl connector, but don't 'squeeze' the connector on both sides: It must be pressed on just one side, or you will be fighting a while. It will come off real slick when you tug the cable. I have done quite a few of these. One young fella with his girlfriend asked me for a hacksaw once in the junkyard... I asked him what he was cutting, out of curiosity: "Oh, just trying to get the speedo cable off an instrument cluster". I was horrified, and offered to go show him how. He had apparently been trying for an hour to get it off, and got desperate. I jumped into the car and reached back behind the cluster. "Click." Off it came.
It is not always easy to release connectors, especially when you have to go by feel alone. I doubt I will ever forget this procedure: My first time out was not pleasant, but I am the type of person to get to the bottom of a problem and find a solution, instead of finding a bigger hammer or a saw. I don't like to damage other parts from a Ford when pulling something I need.
Old Jun 14, 2007 | 05:36 PM
Andy's '79's Avatar
Andy's '79
Thank you all for your answers,I'm going to tackle the problem now
One79one71
Jun 5, 2017 11:28 PM
351WRanger
15
Jan 18, 2017 12:27 PM
Connecticut Calvin
Sep 13, 2016 12:05 PM
winginit
Aug 29, 2016 08:12 AM
inliner
Feb 18, 2004 05:55 AM
