Just bought a used 2001 from a dealers lot and am wondering what updates and recalls have been done besides what's been repaired. Thanks ahead of time ! Here's the number: 1FMNU43SG1EA90351
Hey BBrown...bad vin...check the letter after the S...should be a number..PM me and i'll get you the info.
Ken
Sorry 'bout that. The "G" should be a 6 ! Thanks !!
Build date...10/10/00...isd...1/31/01 5/10/07...speed control recall 9/25/01,,,turned rotors...new pads 9/25/01...rear blower switch tightened 9/25/01...seat belt recall 12/12/01...replace rear drive shaft...balance tires...torque all suspension fasteners, shocks, springs and sway bars 12/12/01...replaced left front hub assembly and both locking hubs 12/12/01...front drive shaft binding...front spring pads broken...replace front drive shaft...replace both front springs 12/12/01...lf wheel molding peeling...replaced
