How do you get one?I just boughta 05 excursion about 2 months ago and have not been able to find out any info.Any help would be appreciated.Thank you.1FMSU43P55ED45415
Thank you very much.I really appreciate it.What do I owe you?james
Build date...8/11/05...isd...8/26/05
5/1/06...recalls 05e16/05b32 completed 7/24/06...oil leak...dye test...no problem found 10/2/06...oil leak...replace rear crank seal/gasket 10/2/06...replace battery
Balance owed...just a thank you...stop in if you're ever in Western Massachusetts...check out the New England Thread regarding the Big June Bash and talk about the meet in Greenfield!!! Some great pictures!!!
Thank you very much,and if i get up your way I will definitely stop by.One other question,any idea what the recall they did was?Thanks again I really appreciate it.I originally was a ford truck guy than bought a Dodge that I was very happy with except the lack of room I needed.I bought this excursion and so far have been very happy.There are some things that I am curious about and wander if I am being to critical.One is that the adjustable gas brake pedal,is it more sensitive as far as vibrations and chassis noises due to it being mounted on the metal cylinder or shaft?And still trying to see what common little traits these have.But all in all happy with my purchase.Thanks again and looking forward to speaking with you again.James
James,
05E16=Recalibrate Engine Control Module 05B32=Install label on coolant overflow tank
Can't help you with your issues, glad you like your EX!!
