Aerostar Ford Aerostar
Need help with distributor
Old Jun 13, 2007 | 06:39 PM
ghenryl's Avatar
ghenryl
Angry Need help with distributor
I changed the sparkplugs on my 94 3.0L Aerostar today (what a joy). The van still ran rough so I decided to look at the rotor and cap.
I replaced them until I could order new parts and thought I had the rotor seated properly but when I turned over the engine I heard a pop ...The tailpiece on the rotor snapped off and fell in the distributor.
What do I need to do to retreive the tailpiece or is the distributor cooked?
thanks
Old Jun 13, 2007 | 09:29 PM
ubereal2's Avatar
ubereal2
Magnet
You need to see if you can get a magnet down to grab the distributer piece that is broken. Most likely gonne need a new dizzy (distributer).
Old Jun 14, 2007 | 12:19 AM
Pablo-UA's Avatar
Pablo-UA
Mark position of distributor and rotor inside distibutor, remove it and repare..... Magnet may ot help you.
Old Jun 14, 2007 | 08:21 AM
ghenryl's Avatar
ghenryl
The piece that broke off was the plastic tail on the shaft of the rotor.
I am hoping I can use my shop vac to suck it out of the distributor. Its just that I dont know where or how far the piece fell into the distributor and if it could have done any damage. Im not knowlegable about the inner workings of a distributor.
As far as marking the location of the rotor...evidently I didnt have it positioned and seated right in the first place. The only thing I can do before taking the distributor out (if thats what I have to do) is to buy a new rotor and make sure its positioned and seated correctly and then mark it.
Does that sound like a reasonable plan?
Old Jun 15, 2007 | 12:18 AM
ghenryl's Avatar
ghenryl
This question has also been posted at the Electrical Systems/Wiring forum.
Old Jun 15, 2007 | 01:24 AM
xlt4wd90's Avatar
xlt4wd90
ghenryl,
There should be a notch on the shaft that the rotor fits over. You can mark its position onto the distributor, and then mark the position of the distributor to the intake manifold.
Old Jun 15, 2007 | 08:28 AM
ghenryl's Avatar
ghenryl
Thank you for your help. Please see my updated post at Electrical Systems/Wiring.
windowman7777
1997 - 2003 F150
Mar 3, 2014 12:36 AM
FordLou
1997 - 2003 F150
Aug 20, 2013 11:10 PM
JonathanN
18
May 10, 2012 09:06 AM
smkf100
Oct 27, 2009 05:40 PM
m000996
May 2, 2008 01:41 PM
