Sponsored by: Auxito
trans seal replace
Old Feb 26, 2014 | 07:29 PM
windowman7777's Avatar
windowman7777
trans seal replace
Mechanic said need tailpiece trans seal replace. How hard or easy for do it yourselfer?
Old Mar 2, 2014 | 11:40 AM
JustAJ's Avatar
JustAJ
Pretty easy if you have the tools and patience. The guys on powerblock TV just did one a couple weeks ago. There are also several YouTube vids.
Old Mar 3, 2014 | 12:36 AM
Torky2's Avatar
Torky2
A leaking extension housing seal on a 2WD trans could be just a worn-out seal. But it could also be a seal that just couldn't seal anymore because of too much yoke movement caused by a worn extension housing bushing.
The driveshaft yoke slips over the splines on the transmission's output shaft. The smooth outer diameter of the yoke rides inside the extension housing's output bushing. The seal presses into a recessed area just behind the bushing. If the bushing is too worn, the yoke moves around too much, and rounds-out the seal, causing it to leak. If that is the case, a new seal will "cure" it for a while, until it gets rounded-out too, and it leaks again.
You can test for bushing wear by blocking the rear wheels, parking brake ON, trans in Neutral. Grab the yoke real close to the trans, and try to move it up-down. Use some muscle. Don't just grab further back, as you will get some tilting play that way, need to grab it right up by the trans. A little bit is OK, a lotta bit is bad. I can't quantify that into fractions of an inch of movement, as I move when the yoke moves, and I lose reference. Doing it from experience.
If the bushing needs to be replaced, it can be done with just the driveshaft out, but it requires special tools just for that purpose to pull and press in the new bushing. I don't have those tools, so when needed I have taken the extension housings off and worked on removing/installing the bushing off of the vehicle. Which also makes seal pulling and installing a simple job. But doing this is not a total beginner's job (note: it is sometimes difficult to assess one's experience over the internet )
Ruckin69
Dec 18, 2018 04:01 PM
markeyd
Aug 28, 2015 07:41 PM
Franko72
Jul 23, 2010 02:45 PM
papajoemrt
1997 - 2003 F150
Jun 25, 2009 09:28 PM
Mustang 5.0
Aug 3, 2006 06:33 PM
