vin help
Old Jun 13, 2007 | 05:33 PM
zora1800's Avatar
zora1800
vin help
You folks are just amazing! Ok here goes ...
F10AR830057
WB = 129
Color = H
Body = 481
Trans C 09
Thank you!!
Dawn
Old Jun 13, 2007 | 06:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10AR830057
WB = 129
Color = H
Body = 481
Trans C
rear axle code 09
Thank you!!
Dawn
F10 = F100
A = 240 1V
R = San Jose CA Assembly Plant
830057 = 1966
129" Wheelbase
H = Sahara Beige
4 = Medium Beige Crush Vinyl / Medium Beige Wicker Pattern Vinyl
81 = 81A Standard Cab
C = Ford 3 Speed Manual All Syncro
09 = Ford 9 Inch / WDM-K-U / 3.70-1 / 3300 lb Axle Capacity
Old Jun 13, 2007 | 07:24 PM
camperspecial65's Avatar
camperspecial65
heres the breakdown of your VIN:
F= conventional cab
10= 1/2 ton pickup, 2 wheel drive
A= 240 c.i. 6 cylinder
R= San Jose, Ca assembly plant
830057 = march 1966 build, I would guess March 1st myself based on the low number assuming the bulids are as broken down in the parts books and other sources...either way, its a very early march build.
Other info off of door tag:
129= wheelbase in inches(8' bed)
H= exterior color, Light Beige
Body= 481: 4= interior upholstery-Medium beige crush vinyl and medium beige bar pattern vinyl.
81= standard trim
Trans=C = std Ford 3 spd Lt duty
09= rear axle ratio = 3:70
I hope this helps you out. If the truck is original and hasnt been molested there a chance it could still have its small metal engine tag which on the 352 was attached near the coil mounting braket. The tag has more specifics about the engine itself as far as when it was assembled, etc.
- cs65
onedcharette
Aug 19, 2011 09:19 AM
ealopez
2004 - 2008 F150
Jun 19, 2009 01:01 PM
Scoarch
Jul 8, 2005 11:57 PM
Mike W
41
May 13, 2004 03:43 PM
Hotshoe
Mar 28, 2004 09:24 PM
