Sponsored by: Real Truck
Cb Antenna
Old Mar 28, 2004 | 08:39 PM
Hotshoe's Avatar
Hotshoe
Cb Antenna
What are you guys running for equipment and where are you installing it ?
Old Mar 28, 2004 | 09:00 PM
BigDawg54's Avatar
BigDawg54
Best bet is a magnetic mount wilson 1000. no regrets with a mag mount. you can leave the base and take off just the antenna or remove the hole thing. Im running a wilson 500 mag with a cobra 29 and it works pretty good. i mounted the antenna base in the center rear of the cab. CB is mounted under cubby slot.
Old Mar 28, 2004 | 09:24 PM
99f350sd's Avatar
99f350sd
Same here the only way to go if you want it to work..Get the best radio you can afford..
rwrogers
Mar 15, 2014 12:53 PM
cbd2
Sep 8, 2011 03:34 AM
SDTruckMan
Aftermarket Products
Jun 30, 2005 09:05 AM
John with beastly 302
Oil & Lubrication
Apr 2, 2003 11:39 PM
BigBrownTruck
Jan 8, 2001 06:19 AM
