Computer Chips & Tuners
What to do?
Old Apr 10, 2002 | 07:10 AM
Gates's Avatar
Gates
What to do?
Question for you all,
I am running a 1991 F150 with a C-6 (was a 5 speed), 10:1 compression, 1965 289 hipo heads ported and polished, 1.6 rr, crane fireball cam 0.484 lift on intake and exhaust 290 advertised duration (220 at 0.050), stock ported intake.
I am still speed density, and I am wondering if I should get a chip, eec tuner, or just swap over to mass air.
any help is greatly appreciated. If you need any more information about the motor let me know.
Thanks
Old Apr 10, 2002 | 10:42 PM
FTE Ken's Avatar
FTE Ken
What to do?
How does it run now? Is it too lean, rich, stumbles, etc?
Old Apr 12, 2002 | 12:11 PM
Gates's Avatar
Gates
What to do?
It has a little idle surge, but after off idle and up to 4000 rpm it is great, above 4400 it is running lean. The cam is good for 5500 rpm (I know beacuse I had this motor in my stang with a holley 650 db and Performer rpm intake before she got wrecked). Plugs look ok maybe alittle lean but thats about it.
Not sure if I should go to mass air or get a chip burned for the speed density. Can you batch fire into SFI and keep it speed density??
Thanks everyone
Old Apr 14, 2002 | 02:56 PM
FTE Ken's Avatar
FTE Ken
What to do?
Quite honestly, I don't like fooling with custom code on 10+ year old vehicles, especially with swapped cams. Its tough for Superchips or Diablo to get it 100% the first burn on a speed density system unless you can provide a dyno chart first. I recommend you change to MAF first.
Old Apr 16, 2002 | 12:29 AM
FTE Ken's Avatar
FTE Ken
What to do?
Deviousfred
Jul 14, 2011 12:10 PM
xclint
3.8 & 4.2L V6
Aug 7, 2008 01:29 PM
cactusflower
Feb 26, 2008 02:46 PM
73beast
May 4, 2004 08:11 PM
ClodsFe
Jan 28, 2004 01:47 PM
