1988 AC compressor coil problems?
Old Jun 12, 2007 | 08:52 AM
barnetto's Avatar
barnetto
Question 1988 AC compressor coil problems?
I am having AC problems on a 1988 F-150 with 302 and auto trans. The compressor coil will not pull the hub in to engage the compressor. I have ~13 volts at the coil connector. I bypassed the pressure switch, the system is charged, I bypassed the switch to rule that out as a problem. I checked the hub clearance, it is .030.
I purchased a new coil and hub assembly and installed it with a .030 air gap. The compressor will still not engage. I checked the resistance of both the old and new coils. It is at 3.0 to 3.5 ohms. I tried bumping the hub plate while the engine is running and the coil energized with no success.
I have noticed the coil harness appears to have a diode wired in. Could the problem be too little amperage to the coil? Any help will be appreciated.
Thank you,
Larry B
Old Jun 12, 2007 | 09:24 AM
fmr9's Avatar
fmr9
Hi Larry
There is another section of the forum devoted to heating and cooling. Some really sharp guys hang out there and I bet one would be glad to help you. If they don't get you going, come on back. Well, come on back anyway.
Good Luck Frank
https://www.ford-trucks.com/forums/forum61/
Old Jun 12, 2007 | 09:30 AM
subford's Avatar
subford
Not sure what you mean by "I tried bumping the hub plate while the engine is running and the coil energized with no success".
The damper diode is to stop the ringing from the A/C coil.
Sounds like you do not have a good ground in the A/C circuit.
Here is a diagram of your system:
http://i54.photobucket.com/albums/g9...stem/PG118.jpg
Old Jun 12, 2007 | 09:48 AM
barnetto's Avatar
barnetto
Thank you. I just posted in the heating and ac section.
Larry B
Old Jun 12, 2007 | 09:57 AM
barnetto's Avatar
barnetto
[Not sure what you mean by "I tried bumping the hub plate while the engine is running and the coil energized with no success".]
The troubleshooting chart supplied with the coil suggested to try to engage the hub by gently pushing against it with a wooden rod. This was to be done with the engine running and the ac switch on. If bumping the hub plate engaged the copressor, then the air gap is too wide or the coil draw is insufficient.
I hope I explained this properly.
Old Jun 12, 2007 | 11:09 AM
subford's Avatar
subford
What I was wondering is did it stay in when you did this?
Old Jun 12, 2007 | 12:23 PM
F150xlt's Avatar
F150xlt
Here's the schematic posted by Subford.
If you have 12 volts at one end of the coil, to complete the circuit you need a ground on the other end of the coil, (Black wire).
Disconnect the plug and measure the resistance on the end of the plug Black wire to the negative of the battery terminal. Should be close to zero.
Old Jun 12, 2007 | 08:18 PM
barnetto's Avatar
barnetto
I was checking the ground and harness connections when I noticed the pressure switch wiring was loose inside the plastic connector. The wire had pulled loose from the metal crimp on the connector. When I jumped the switch yesterday, the connection was probably bad. I had voltage, but not enough current to energize the coil. I crimped a new connector for the pressure switch and now the coil pulls the hub in and operates the compressor.
Thank you for your advice.
Larry B
scott79
Jun 13, 2021 02:05 PM
rshiver
Aug 23, 2015 02:21 PM
john jamieson
1983 - 2012 Ranger & B-Series
Aug 6, 2015 04:44 PM
navyguy79
Jun 23, 2015 03:45 PM
granny_rocket
Jul 14, 2014 07:42 AM
