'96 ac problem
Old Aug 3, 2015 | 08:26 PM
john jamieson's Avatar
john jamieson
'96 ac problem
I have a '96 ranger with the 4.0. The ac has a leak in or around the compressor.I bought some leak detection dye. The man at the parts shop said to put it in and then bypass the low pressure over ride switch to make the compressor operate with out wasting refrigerant. How is this done and where is this switch? Or should I put the dye in and then just fill it untill the compressor kicks on?
Thanks for any help.
john
Old Aug 4, 2015 | 07:14 AM
pawpaw's Avatar
pawpaw
I recently had to add a can of refrigerant to my 99 & I added it until the compressor switched on. Only took about 30 seconds for the compressor to begin short cycling, then it would stay on longer as the low side psi numbers began to build toward normal. It took exactly one can to bring everything up to normal. Don't add more than one can.
Old Aug 6, 2015 | 04:44 PM
g_k50's Avatar
g_k50
I would agree to put the dye in then fill until the compressor kicks on.
It's most likely leaking from the O-rings where the hose connect to the compressor.
Emerald Navi
Jun 20, 2013 08:10 PM
norm9759
Sep 22, 2010 02:02 PM
302VAN
Apr 3, 2008 03:22 PM
slychicken37
Feb 14, 2007 09:10 AM
crawdad
Jan 18, 2006 07:17 PM
