AC compressor not engaging
Old Jul 16, 2015 | 09:53 AM
scott79's Avatar
scott79
Hey fellas, as the temps are rising I finally turned the AC on and nothing--only hot air coming out! I popped the hood and noticed the AC compressor not engaged. After reading thru some posts, I decided it must be the low pressure switch but first I checked to make sure I had power to it---yes, checked the fuses (#1) and it was good. So, I replaced the low pressure switch and still nothing---compressor not engaging!! Also I added refrigerant just in case. Any advise for what could be my problem? Thanks
Old Jul 16, 2015 | 10:12 AM
farmert's Avatar
farmert
You could jump the low pressure harness to see if you problem is on the low side, but since you added refrigerant, I doubt this is were your problem lies. Wiggle the harness behind the compressor, it may be on the high pressure side. When I got the 96 C&C, that harness was loose, and the compressor would not run.
Old Jul 16, 2015 | 11:23 AM
JCart's Avatar
JCart
Just to clarify when you say not engaging you mean the clutch is not triggering or the clutch is triggering (clicking and shifting into the pulley) but not gripping the pulley? If it's the later, there are iirc 1 possible 2 shims (washers) that you can remove behind the clutch (piece that shifts into and grips the pulley). To get at them just undo the Center bolt, remove clutch and shims and reinstall, without shims.
Old Jul 16, 2015 | 11:33 AM
scott79's Avatar
scott79
I mean the clutch is not engaging at all. When I turn the AC on, nothing happens, no clicking, no nothing.
Old Jul 16, 2015 | 04:28 PM
dclack's Avatar
dclack
First thing to do then is to test the coil by applying 12v directly to it. If it doesn't pull the clutch in, then the coil is bad.
Old Jun 12, 2021 | 08:16 PM
Jwilson19's Avatar
Jwilson19
3rd Gear
My A/C is doing this too. Where is the coil you are talking about?
Old Jun 12, 2021 | 09:57 PM
z31freakify's Avatar
z31freakify
He' talking about the AC compressor connector.
Old Jun 13, 2021 | 02:05 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
This.
Does the blower fan still work? The high switches are known to die, when that circuit is open...no power flow to the compressor. Should be a black and grey white wire I think at it. Just a couple of alligator clips are all you need, ground one pin and hit the other with battery voltage. There is also a diode up stream, but those rarely die and just allow one way voltage flow.
Your charge is now off also since you shot some refrigerant in there. How much is anyone's guess as you cannot add gas to a system that is off and pressurized in my experience.
mahause
40
Nov 22, 2013 06:53 PM
pecanflyboy
Nov 5, 2012 12:33 PM
michaelbrainardatwor
Dec 9, 2007 08:01 AM
cobramustangboy
Jul 3, 2007 12:43 AM
wardenj
1978 - 1996 Big Bronco
Aug 11, 2002 11:10 PM
