Troubleshooting AC electrical problems
Old Aug 23, 2015 | 09:17 AM
rshiver's Avatar
rshiver
Hey everyone, I have a 96 F-150 4.9. AC compressor will not engage. I have checked for power thru the low pressure and the hi pressure switch, everything is good. The only place I don't have power is at the compressor. I looked at a wiring diagram and it appears the power routes back through the PCM. My question I guess is does the PCM control the power to the compressor?
Many Thanks...
Old Aug 23, 2015 | 12:02 PM
F350 1990's Avatar
F350 1990
Your next checks if there is no voltage at the compressor
Wiring & fuses
A/C clutch resistor diode
EEC
Old Aug 23, 2015 | 02:21 PM
rla2005's Avatar
rla2005
Many Thanks...
No, the PCM does not turn the AC compressor On/Off. That tie in is the signal telling the PCM the compressor is engaged. In theory the PCM uses that to calculate engine load.
NapaValley
Nov 28, 2018 10:34 AM
omegalita
May 7, 2011 06:46 PM
TheKirbyMan
Sep 18, 2010 10:01 PM
madfinn
1983 - 2012 Ranger & B-Series
Mar 31, 2004 10:32 PM
cbird
Mar 20, 2004 01:17 PM
