Won't turn over
Old Jun 10, 2007 | 09:57 PM
RVOOPS's Avatar
RVOOPS
Won't turn over
Hi Everyone;
I hope someone can help me. My son has a 92 Explorer. The starter will engage but won't turn the engine. I had him pull the starter and try it independently and he said it would kick in and spin. I also had him look at the gear teeth and he said they looked ok. I also had him try moving the ring gear with a screwdriver and he said it moved although he said he only moved it a couple teeth, then put it back together. The starter will still would engage but not turn at all. He also said the battery seems to have a good charge. Please help!
A Big Thank You in advance
Old Jun 11, 2007 | 12:51 AM
ckrichard's Avatar
ckrichard
First off welcome to FTE.
First try another battery.
Try running a heavy gauge wire directly from the battery and see if it will turn the motor over. This will see if the wiring has gone bad and needs to be replaced.
Also, try pulling the plugs and see if it can turn it over. If it can and when you put the plugs back it quits working then i would say the starter is bad.
Did the explorer's electrical system give you any problems before this started?
Chris
Old Jun 11, 2007 | 08:01 AM
Backin72's Avatar
Backin72
Can he hear the fuel pump prime when putting the key in the on position? He should hear it prime for about a second or 2. If not, it could be the Inertia/Fuel Cut-off Switch. It's located just under the carpeting in the front near the hump where the firewall and floor meet. Press it and see if that fixes his problem. Could be a bad fuel pump, a bad ground on the pump, or even a fuse.
Old Jun 11, 2007 | 10:01 AM
RVOOPS's Avatar
RVOOPS
ckrichard ;;
Thank you. I'll give him a call and have him try it. I assume you mean to jump from the battery, directly to the starter? He did say that the Explorer seemed to be sluggish lately.
Backin72;;
Thank you also. It's good to know about that switch. Would that prevent it from even turning over though?
Old Jun 11, 2007 | 12:46 PM
87 XLT's Avatar
87 XLT
Ditto to what ckrichard mentioned.
When I had the same problem on my Ranger I simply added a jumper cable between the positive post on the battery & the starter relay. Still would'nt crank.
Added the cable between the negative post of the battery & the engine block & it fired right up, so I knew that the negative cable was shot.
Old Jun 11, 2007 | 12:58 PM
Backin72's Avatar
Backin72
Originally Posted by RVOOPS
Backin72;;
Nope, my bad. I had misread your post.
ArdWrknTrk
130
May 21, 2021 11:45 PM
BuckHammer
55
Jan 31, 2011 12:59 AM
vze2sgxa
Oct 28, 2010 07:15 PM
jmacd27
Jul 23, 2008 08:17 AM
blueovalinvestments
Oct 27, 2004 07:58 AM
