Help 97 Explorer wont start? 02 Codes?
Old Jun 8, 2007 | 03:41 PM
termitedh3's Avatar
termitedh3
Turns over checked fuses (ok) fuel relay (ok) pulled these codes:
P0135, P0141, P0153, P0155, P0156, P0161, P1151 Any ideas what to try to get this thing running?
Old Jun 9, 2007 | 02:13 PM
ReAX's Avatar
ReAX
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
So you have 4 heater circuit malfunctions and bank 2 pre and post o2 sensors are shot. I'd first check the ground, but it sounds like you need 4 o2 sensors. Have you used some kind of carb cleaner or fuel additive lately?
Old Jun 11, 2007 | 07:10 AM
termitedh3's Avatar
termitedh3
Thanks for the reply. No the engine was rebuilt. they might have?
Old Jun 11, 2007 | 07:19 AM
ReAX's Avatar
ReAX
Some additives and carb cleaner are not o2 sensor compatable. To wipe out four of them at once, it's either a chemical problem or one of the wiring harnesses is cut.
Old Jun 11, 2007 | 01:03 PM
87 XLT's Avatar
87 XLT
Heres how it's wired. Fuse 2 (30 amp maxi) feeds the PCM power relay. PCM power relay feeds fuse 11 (15 amp mini) & this fuse feeds the O2 sensors.
Both fuses are under the hood in the power distribution box. Are you sure they are both OK?
Does the check engine light come on and the fuel pump run with the key is turned to run?
Old Jun 11, 2007 | 02:21 PM
termitedh3's Avatar
termitedh3
Yes the fuel pump runs and the check engine light is on.
Old Jun 11, 2007 | 03:56 PM
87 XLT's Avatar
87 XLT
In that case, like ReAx mentioned, it sounds like a wiring problem.
If the engine was just rebuilt, might be a pinched wiring harness between engine & bellhousing or bellhousing & trans..
Old Jun 11, 2007 | 04:02 PM
termitedh3's Avatar
termitedh3
Thank you for the info. we will check the wiring harness.
Warhippie
Jul 19, 2014 01:22 PM
Rlawmulching
Oct 10, 2013 10:41 PM
awillo0406
20
May 7, 2013 02:58 PM
MiamiPSD
Feb 6, 2013 05:08 PM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
