Mazda 5-speed blues
Old Jun 8, 2007 | 03:15 PM
cowchasinsix's Avatar
cowchasinsix
Mazda 5-speed blues
I have 1989 F-150 4x4 w 4.9 and Mazda 5-speed. The tranny nobody likes on this site. Truck needs a new clutch (slave cylinder is bad CURSE internal slave cylinders!). Only problem is this transmission will slip out of 3rd gear when slowing down. That is the only problem it exibits but I'm wondering after all the reading on this site regarding this "weak" tranny if its worth clutching if trans is gonna go before long. Can anybody tell me what symptoms their Mazda's gave before taking the trip. Is it worth putting clutch in? Probably wouldn't spend the money if I know transmission is on its way out. Rest of the truck is OK--nothing special does run good and gets decent mileage. Just wondering.
Old Jun 8, 2007 | 03:44 PM
jas88's Avatar
jas88
I like the Mazda quite a bit. I put 225K on the one in my '90 F150 and the only problem I had was the leaky plugs on the top cover, which I replaced. Towards the end, it probably needed the top cover and shift forks replaced as it was kinda hard to get into 2nd gear, but I just put up with it. My current ZF is kinda cranky about going into reverse and grinds sometimes going to 4th - if I run across a good M5R2 for a good price, I'll probably swap.
Old Jun 8, 2007 | 05:18 PM
Dean88's Avatar
Dean88
Originally Posted by jas88
I like the Mazda quite a bit. I put 225K on the one in my '90 F150...
Sounds like your quite lucky, my Dad's '89 F150 went out after 120,000 and his '94 F150 went out after 145,000. I would just rather keep my ol' 4 speed in my 87 F150. Does anybody know what the 4 speed in the 87 F150 is? My truck is a 302 4x2.
Old Jun 8, 2007 | 09:31 PM
jas88's Avatar
jas88
The only repeated failure of the Mazda I am aware of is when the shift rail plugs at the top leak all the fluid out and they burn up the oil slinger. I won't put up with a truck leaking like that so I fixed mine before any damage was done, but a buddy had his ('89 4x4 SC) go out at about 145K for that reason.
Old Jun 8, 2007 | 09:53 PM
Bruce R Leech's Avatar
Bruce R Leech
Mazda are good if you take care of them. but if you beat them up they will get even with you. it sounds like he either has a bad pilot bearing or a bad main shaft bearing that is causing it to pop out of 3ed gear. if he keeps driving it with out taking care of that problem the trainsmition will explode. it is only poor maintenance like this that causes peple to think the Mazda is a bad trainsmition.
Old Jun 8, 2007 | 11:09 PM
hogdogs's Avatar
hogdogs
Amsoil ATF will make these trannys shift smooth as silk! I wouldnt'a thought that ATF was a replacement but it did fine in an f-550 ZF equipped truck...
Brent
Old Jun 8, 2007 | 11:13 PM
GypsyR's Avatar
GypsyR
I bought my '89 (cheap) some years ago and it only had first and second gear. I figured what the heck and tore into the transmission. I found bad bearings and a synchronizer on the reverse/fifth shift. Took a shot on a "junk" salvage yard transmission and by pure luck the parts I needed weren't among its problems. I put it toghether and drove it daily for three years. The pilot bearing let go and I chickened out and finally had a pro trans shop look into it. They replaced the input shaft bearing and two synchronizers that "looked a little worn" and OK'd it. To my suprise actually. I sold the truck to my son in law who's been driving it as his work truck for about three years now. Smoked the clutch once but the M5 still drives and shifts like when I first fixed it. Which is to say quite well, always was a tad stiff going into second though.
I never really "liked" the trans simply because it didn't shift like a Mustang 5 speed. Bad? I sure don't think so. Mine gave better service than I ever could have imagined. Still doing so.
Old Jun 9, 2007 | 09:35 AM
Bruce R Leech
Brent
Hotdogs is right both the ZF and the Mazda like a good synthetic Mercon and they like it chainged at 30,000 miles and they are very touche about the level being a little low or High.
change those rubber plugs
Old Aug 8, 2007 | 01:51 PM
TheRoadVirus's Avatar
TheRoadVirus
I have 257km's on my tranny. Clutch has gone once or twice (once that I know of for sure) and I've never had a problem. Actually I find it to be quite durable seeing as I beat on it.
Old Aug 8, 2007 | 02:06 PM
Talyn's Avatar
Talyn
I was told to fill mine over a little on my mazda.
I run 20w50 in mine. Works great, shifts well.
The rubber plugs and the nylon shift bushings are the mazda's week points.
Low fluid will kill a mazda in seconds. And the shift bushings if they break, which is inevitable, will not allow the shifter to shift gears to well, which could be why your popping outa 3rd.
Other then that, the shift forks could be a bit damaged.
Mine likes to pop outa fifth if i hit a hard bump. Which is scary, thank god for rev limiters kicking the cruze off.
I'm not sure exactly what holds it into gear, that allows that slipage.
The nylon bushings i'm talking about i can get the part number for you. They are not greased in the factory, so they dry out and crack.
Break apart, and then you have a super sloppy shifter.
First was in the dash before i got it fixed.
UP and to the right. hahaha. now its good!
Old Aug 8, 2007 | 05:56 PM
RedZerOne's Avatar
RedZerOne
One thing's for sure. Who ever the guy was that decided on the internal cylinder on those sure did make life hard for the rest of us.
I'd probably look at replacing with a ZF5 if you're planning on towing or off-roading, just to have a stronger trans. Just my two cents.
Old Aug 8, 2007 | 08:53 PM
lunki98's Avatar
lunki98
Sorry to high jack this thread. Where are these plugs and how hard are they to change/fix. My 1990 is leaking and I just keep adding fluid.
Thanks for any help
Luke
Old Aug 8, 2007 | 11:53 PM
Mr. M's Avatar
Mr. M
what years were the m5od in f150's? And what years were the zf tranny used instead?
Old Aug 9, 2007 | 12:08 AM
Navy Jet Mech's Avatar
Navy Jet Mech
I'm not sure if I have the M5OD or the ZF, but I occasionally have to double-clutch into first from a dead stop, second is a little tricky, and fourth can be an outright pain. A lot of this is probably shifter issues and captain's chairs that sit a little higher than the stock bench seat--therefore making the clutch harder to push completely down. I'll get under the truck before too long and see what tranny it has.
Old Aug 9, 2007 | 08:06 AM
Talyn's Avatar
Talyn
Navy, it sounds like your master or slave is going bad. Try bleeding the lines.
The mazda was in most of the f150's with 302's
Very very rare to see a zf on a 302.
IF the motor was a 351, it would have a zf transmission on a 150.
The i6's came with m5od's also.
There isnt' anything wrong with internal slave on mazda, except when you want to replace.
I'm not sure on the purpose of it, but the bleeder is hard to get at. It is VERY tiny.
The mazda is an aluminum cased transmission. the zf is made of heavier material.
I've successfully hauled with a mazda 5 speed. It really depends on how good you are with a clutch. 4th is 1.1 ratio, and 5th is .72 i belive.
Anyone know final ratio on the zf 5?
I honestly woudln't trade my mazda for a zf in my 302.
1st to 30, 2nd to 45, and 3rd to 60..
Mazda is a fast tranny.
ZF is
1st to 10, 2nd to i duno....
Basically if you wanna pull and work. zf is the way to go.
