Lately I have had a weird problem that even Ford cant figure out. I will be running down the road, the speedometer will drop to zero, and the transmission will start cycling in and out of gears. If you let you foot off the gas, the speedo returns and the trans shifts into OD, but as soon as you hit the gas, it happens again. We have replaced the vehicle speed sensor in the rear end, and the PCM. This happens sometimes once a week, sometimes 2 or 3 times a day?
I have read posts about the PSOM going bad, but this truck has a mechanical odometer. Where is the PSOM located?
Any ideas?
Thanks
Todd
I'm pretty sure you have an electronic speedo. Well it sounds like something is shorting out. Make sure the TPS sensor is not shorting out, check the grounds also.
... and the transmission will start cycling in and out of gears ...
Did you get this problem resolved? I have a similair problem with my transmission cycling in and out of overdrive. Just wondering if you found a solution.
Just a shot in the dark here, but what about a poor ground connection? I heard somewhere that E4OD's would chew up some rear bushing due to current going through the body of the transmission in the wrong fashion due to inadequit grounding on the whole vehicle. Maybe run an extra wire from the body of the trans to the battery for an experiment.
I actually have a 4R100. But I will look at this and give it a try. I'll let you know if it makes a difference.
I'm going from memory here, but I believe the trouble codes I read last night were P0500 and P0443. I wrote them down, but I don't have my notebook with me right now.
I replaced section of wiring harness that runs over the top of the tranny and the problem went away. Ford wrapped heat shield around it so I think they know they have a problem there.
Todd,
Thanks for the info. The Trouble codes say I have a malfunctioning VSS. I'm going to replace it, but I will try to inspect the wiring at the same time. You said you replaced your VSS. Were those the wires you replaced also?
Alden
Thanks
Todd
Well, it took a while, but I found my problem. The two wires from the OD button to the PCM were shorted together somewhere underneath the coach. I ran some temporary wires, and it runs like a dream!
